Putting my much loved Cefiro up for sale to fund the purchase of a rally car and I unfortunately don’t have space to keep both.
I’ve had the car for about 3.5 years and have spent that time fixing and improving things and have only taken it to 2 hill climbs and 1 Winton day since owning it.
Perfect turnkey track car for grip or drift events. It’s got a couple of things done to it so here goes…
Located in Melton, 3337
Check the FB link for photos: https://www.facebook.com/media/set/?set=a.10153030324752897.1073741828.521242896&type=1&l=e1f1920830
Price: $11,500
1988 A31 Cefiro – sunroof model
Currently registered on Vic Club Permit
Has been compiled and can be registered
Also has old engineers certificates for the RB25 conversion, wheels and to register as a 2 seater which are valid in NSW
ENGINE / GEARBOX
Series 2 RB25det gearbox with new speedo sender
NPC button clutch and center bearing replaced at the time of fitting (approx. 20ks)
Completely rebuilt series 2 rb25det engine. (same engine that matches the engineers certificates) with approx. 20ks on it (mostly road k’s – drove it back from QLD to VIC - and only 5 or so track events)
Scat rods
JE forged pistons
Total seal rings
Engine was fully balanced with the clutch flywheel and balancer all attached
Runs 8:7:1 ratio so is very responsive and not lazy off boost.
Head had all tests done for warping and cracks etc. and all new valve guides fitted.
Permaseal multilayer steel headgasket
Brand new nissan standard oil pump
New front and rear main seals
New tensioner, idler and gates racing timing belt
New water pump
New cam cover seals and cam gear seals. etc.
Wrinkle coated cam covers.
WALBRO (genuine) intank fuel pump mounted properly to avoid any fuel surge
Fuel pump wired directly to 12v via relay (wiring recently re-done to remove factory relay)
Apexi power FC ECU with hand controller
Greddy copy front facing plenum that has had the ports cleaned up on and the manifold faced for proper seal to the head
Front mount
SARD 850cc injectors in standard fuel rail
Drift fuel pressure regulator with speedflow lines
D1 remote header tank for the cooling system.
Added overflow bottle to fit in the available gap
Massive 52mm alloy radiator and still running standard clutch fan
LS2 D585 coil pack conversion (from a US spec Hummer)
GARRETT GT2876r dual ball bearing turbo with internal wastegate
VH41de airflow metre with custom pod adaptor and filter
Greddy profec electronic boost controller
Reinhard catback with twin 4in pipes and removable mufflers and silencers
100 cell cat
Circuit Sports Exhaust Control Valve (better than the Apexi design)
Oil filter relocation kit and 15 row cooler recently relocated to drivers side (1 event ago) with all brand new Teflon lines and Proflow fittings
PWR powersteering cooler
Power steering lines recently replaced with braided lines and fittings
New engine mounts at time of engine rebuild
Near new Nismo gearbox mount
Allstar performance custom alloy catch can with proflow filter and speedflow lines.
Tuned by Chequered making a VERY responsive 235rwkw
DRIVELINE/BRAKES
Full R33 5 stud conversion
Aftermarket front hubs with new wheel bearings 1 event old
RDA slotted front and rear R33gtst rotors machined 1 event ago
Brand new QFM A1RM pads front and rear (1 hill climb old)
R33gtst master cylinder and booster
HEL braided lines front and rear
Almost new Kaaz 2 way recently assembled and set by Trans Gears & Diffs
Near new customer 2 piece tail shaft with genuine Nissan centre bearing (500ks and 1 event old) by Melbourne Driveshafts
SUSPENSION
Currently running a ‘grip’ alignment and ride height
Near new (<1000ks) Shockworks coilovers. Height and damper adjustable, installed and tuned by Shockworks for the car.
SELBYS front and rear sway bars with 3 way adjustment
Front strut brace
Adjustable front castor arms
Hardrace extended tie rods
GKTech adjustable tie rod ends
Gusseted front LCAs
New front sway bar bushes
New front and rear LCA bushes
New front and rear ball joints
Adjustable rear camber arms
Hardrace adjustable rear tension rods
GKteck hicas elimination kit and adjustable toe arms
Hicas lock bar
Solid subframe collars
INTERIOR
The all-important and very rare – Left hand vent cover!
Dildo shifter
Replaced gear boot
Rear seats removed
Metal covers over seat hole to boot and parcel shelf
All holes filled with sikaflex
Genuine BRIDE Artis II with stylish cheetah patch on wear spot
Autometer boost gauge
New white dash cluster LEDs
Auber Oil Pres, Oil temp and Water temp digital gauges linked to light up buzzer
Kill switch wired to battery in the boot
MOMO pedal set
50mm steering wheel spacer
Deep dish steering wheel
Fire extinguisher
EXTERIOR / WHEELS
Respray in Lexus ISF Blue
S3 tail lights
S3 Chrome grill
Factory metal guards have been flared roughly 50mm in the front and 80mm in the rear. They have been properly done with the standard bodywork cut, stitched then glassed/filled and painted.
Full URAS bodykit
DMAX roof wing
Carbon wrapped pillars
Tow straps front and rear
18 x 9.75in +20 XXR 527 wheels front and rear
Edited by konect
https://www.sau.com.au/forums/topic/457732-1988-cefiro-with-built-rb25/
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
    • Any recommendations for what would be the easiest welding type to start on, for sheet metal rust repairs and maybe some exhaust piping too? Seems like MIG is the most common. Would gasless MIG be ok to learn on and do some simple jobs? I have a stick welder which has a Lift TIG setting, but i'm more interested in getting whatever's easiest to do, and most suitable, rather than using what i have.
    • Is the UP Garage in the US of Ayyeee even the real UP Garage?
