Truly an awful effort on that one!
I must say though, that I disagree strongly on the whole "biggest volume after the turbine outlet possible" school of thought. Respected turbo people (read, dev engineers at Garrett) have stated publicly that the very best turbine dump is a conical taper expansion from the diameter of the turbine outlet up to the diameter of the required dump pipe size. Said conical expansion needing to be about 10° included angle, or somesuch small angle. Of course that is a little difficult to package in an engine bay, so we do have to accept compromises. But as far as I am concerned, the "smaller" turbine pipe that results from a split dump is not an issue, provided it is as nicely shaped in terms of the expansion and the bend downward as possible. In fact, a smaller turbine pipe actually makes it easier to get a more respectable conical expansion and a slightly more decent looking bend down than going straight to the largest pipe. The fringe benefits of keeping the nasty turbulence of the gate exhaust flowing sideways into the turbine exhaust, right at the point where the turbine flow exits the casting is almost a bonus, rather than the original aim of the design.
Of course, I have nothing good to say about the divided dumps (the HKS ones and the copies thereof) where the return was really close to the top. They do need to take the WG gases as far downstream as possible before putting them back in.
I agree that obtaining the best pressure drop across the turbine is the goal. But I disagree that a drainpipe dump is the way to achieve that.
This is pretty much what I wanted to say but I lack enough knowledge to write it coherently, but basically the turbine wheel and the space in which it sits is not a 3 inch diameter, so why would a split dump pipe with an actual dump pipe of say 2 and a bit inch that expands to 3 be a restriction? As long as its larger than the turbine wheel itself it should be able to handle the air flow sufficiently.
Also my waste gate pipe is the entire length of the dump and joins just before the front pipe, is that long enough to be effective? Just out of interest
But, I bought both a split pipe (wen the extra mile of ported flanges to give a good smooth entry taper to both pipes) and a bellmouth pipe, and tested back to back....bellmouth was much better, car pulled noticeably harder. I put it down to one of those 'ideal on paper but not in use' things....as in, if you were designing a setup completely from scratch you could come up with a better setup, but fitting a premade product into a premade space and throwing in only 1 aspect of the 'ideal' design like the conical taper, just doesn't cut it so the 'as much space as possible, as soon as possible' design of the bellmouth worked best.
Totally fair. You and others have made the same claims and I reckon that with what's available off the shelf, and the variability of those products your results are valid. I'd like to think that someone could/would spend enough time to design and build a split dump for RBs in Skylines that incorporates the most ideality it can and see what happens.
I reckon that if you were gung-ho about it you'd piss off the air-con, move the turbo forward so you could have a longer straighter conical exit from the turbine, etc, etc. The sad thing about that is that there's not way you'd do it, because going to that effort for a standard dump pattern turbo seems well silly. You'd put on a much bigger turbo with external gate as your first choice.
Yeah, they're the only ones worth considering. Mine rejoins at the bottom bend. I'm in two minds about where the best place down there to re-introduce the gases actually is. Practicality, buildability and installability often get in the way of what is probably the best aero solution.
100% correct. You can see this in carbie design too. There's a short radius into the venturi, then a long, small angle cone out of the venturi. That's because the transition from large to small produces less turbulence than the transition from small to large, so you need to take more care with small to large. IIRC its 7 degrees but as you say, its impractical to go too small with the angle because it makes the cone too long.
With the mess of turbulence coming out the back of the turbo I don't think perfect transitions matter too much. Get the exhaust out as quickly using the largest tube possible, with the least amount of bends works for me, with gentle transitions preferably. Sometimes a decent split dump just can't work, due to space constraints, or the costs involved in running two pipes where one should be.
I have never seen a good internal gate split dump design, they all step out from the gate, then back into the hole in the flange, causing flow restrictions at the step down. I have never seen one where the merge was any good either, I would be die grinding them out to the size of the gate pipe after welding if I made one, but you don't want it merging into the small dump diameter either. When I merge an external gate I make sure the pipe after it is similar (or greater) in area than the two merging pipes, then step it down gently later if required. Hardly any split dumps on the market do that, most can't even get a decent merge angle.
  • Like 2
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
