Entries Open: Sauvic Deca - 25th July 2015 - Shepparton - Its Back!
Yeah that's my concern, that looked sketchy in that recent vid in the dry.... no real run off there... tree's oh god the tree's.
Ah don't be a pussy!
You can go as hard or not as hard as you like, often slower can be a bit faster (especially in the wet). So it's only dangerous if the pilot is being dangerous :)
Given how wet I was one year, after standing in the torrential rain for a good 15mins directing cars, safe to say no matter what the event goes on! Viva la DECA!
(I may or may not bring cheater EVO if weather looks sketchy lol).
Considering the event starts at 7:30 and is nearly 2 hours away, even for northies, you might want to reconsider your departure strategy :thumbsup:
  • Like 1
Thanks for confirming event start Birds.
Amend departure time to 5.30am @ Greensborough, this should give ample time to arrive following scrutineering and driver debrief.
If there is not many people interested in driving up, I'll just head off per own schedule.
Cheers
I used to leave eastern suburbs latest 5am back when deca started 8am...
Just in case anything goes wrong or you have to sort out anything with your car and scrutineering/licensing it's always a good idea to get there early rather than on the dot!
think there 10+ spots left so get it in, should be plenty of runs for every-one with the limited entries.
I've got the CAMS license, mate who's done a DECA with us before is coming too, just getting AASA posted in the mail today.
Oh yeah, we're sharing the same car (mx5 - nohomo)
Do we just apply separately?
go though the online form and you will see an option for shared car.
both need to put though an entry but mark that you sharing car so you get put in same group a bit apart so you have time.
I remember that day.
Submitted and paid!
Good stuff Jack! You and Jarrard?
Guest
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
