So who's playing? I picked up mine on the way to work tonight and won't be able to give it a go until friday.
Any PC users experiencing the glitchy, jumpy graphic issues that are being reported?
I'm watching a mate play it now on his laptop and he hasn't had an issue yet. But in saying that, another mate is having big issues while running 2 gtx980 titans in SLI.
From what I've seen for far, the game looks freaking awesome.
https://www.sau.com.au/forums/topic/457774-batman-arkham-knight/
Is this the one that came out on PS4 as well (released midnight the night before last)? My son picked his up yesterday morning and absolutely loves it (was up till after midnight playing last night with a mate). That's all I know - I only play driving games, so don't get into any of that other stuff.
Benchmark ran nicely on my build.
Gameplay is very poor though, doesn't feel smooth at all and and I need to have setting very low for the build I have.
Most other AAA titles run High to Ultra detail 2560x1600 at 60fps+
Terrible port, very inefficient or poorly optimized.
My new card arrived today so i'll install that when I get home tonight and see how it runs on full settings.
I'm playing it on all low settings at the moment with my current card and it struggles (only a 1GB card so I was expecting it)
From what I've read of the last patch, most things should be fixed.
Can't wait to play it on proper graphics
I'm loving the game at moment.
The story is excellent as well as the game play.
The plot twists in the story have been crazy, would never have picked them. They have really stepped it up to finish the series off.
Also I haven't had any of the graphic problems at all. The new card is running like a dream.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
