Mine didn't.
Ran fine until I spun bearings.
and I'll be looking at better quality than a bunnigs washer.
going to the local bolt master to see if the have any high tensile washers in double thickness.
Seems odd how some people have this issue and others don't. Any idea if your block came from an R31 or a VL?
thought about this.
Depending on block machining, head machining, and gasket thickness used, will depend if they just clear, or just foul.
the more you skim off, and thinner the gasket, the more likely to need the extra washer.
  • Like 1
I have a r31 series 3 block and had 2mm skimmed of the 25 head and using 1 washer holding 21psi with no issue
  • 4 weeks later...
Thought I would report back guys in-case this help anyone else out. I ended up running dual washers, standard 26 washers plus the ARP washers. Standard OEM 26 head gasket, and went another 15 ft/lb over on the torque. So far it's done 2 track days and a few runs here and there, no signs of pushing coolant and comp/leak down test done the other day was all good. Holding about 26psi fine.
Big thanks to all those that commented, and especially those that hinted about the dual washers.
Cheers.
  • Like 1
How come u didnt use a multi layer steel gasket mate?
I was concerned that the block face may have been out slightly, as I wasn't sure the washers would be the fix at the time, hence I decided to go composite thinking I would have better success that way if the block was out . That and other people have reported pretty good success with them after only doing ARP studs on standard NEO's and the like, similar boost to what I am running.
I suppose time will tell if that was a bad decision, I did work it hard at both track days but with only about 5 mins rest time at each event.
  • Like 1
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
