Hi,
I am doing a round of modifications to my r34 gtt rb25 neo that is basically copying a setup that should make ~330 RWKW on 98
Is there much to be had at this level from getting the head ported?
The engine has 100,000 km on it so could be due for a freshen up top, I was planning on doing stem seals since I am replacing cams and springs anyway but was going to leave the head on, but this would be a good time to pull the head off and get it ported if the gains made it worthwhile and install some arp head studs.
I read on the 'Lewis engines' website and it seems like a worthwhile upgrade, is there any machining shops that would come recommended by SAU members?
https://www.sau.com.au/forums/topic/457791-rb-25-head-porting/
What he said.
At 330rwkW there is absolutely no need to port the head. It is very possible to get to that sort of power just by using boost. If you do port the head, you will need a turbo that can make the target air flow level at lower boost. This might ultimately mean the difference between using a GT3076 or a GTX3076 (just to pull an arbitrary turbo size out of the air. The GTX are optimised to make power at higher pressure ratios.
If you do port it, and it is done well (sensibly, not just hogging shit out of it) then gas flow will increase even before the turbo is up on boost, so you should improve response.
But.....How else would you spend $2k?
Anyone can hack up a port.
Seen it too many times to mention. :/
The more boost you run the less runner size you want imo, so a little bowl work is fine, and I agree with port matching, but I would like to actually add material to the port to increase the gas speed before the valve.
Just think how long the valve is open for at 8000 revs, and what speed the air needs to be going to fill the cylinder in that time...
Apparently stored correctly in a 44 drum it would be good for 3 months max, not sure I would go through it that fast especially considering the car only comes out to leave town and It wouldn't make it to the next servo selling e85
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
