Hello, I have some oil problems in my rb25det neo, Im going to block one oil feed and a 1.1mm in the other.
My problem is that there is already 2x 1.5mm restrictors fittet,
How far down can you knock down the factory 2mm and the 1.5mm? Or do i need to remove the 1.5mm? :)
https://www.sau.com.au/forums/topic/457824-triple-oilrestrictors/
Have you read your OP? It is totally inconsistent. It talks about 2x1.5mm and then it talks about there being 1x1.5 and 1x2mm. Didn't sound like you knew what was going on.
On top of that, do you understand that a 1.5mm restrictor upstream of a 1.1mm restrictor is going to mean that the total restriction is going to be tighter than a 1.1mm restrictor on its own?
I don't know for sure but seeing how short they are I would think you could get three in the hole no problem, Get a drift and tap the existing ones down to make room for the new one so you don't have to hit it too hard potentially closing up the restrictor.
There is heaps of room to tap down restrictors and add other smaller (but not larger) ones.
If going larger you need to remove the smaller one in there, i use a self tapping screw run into the hole of the old one and use a old shifter to tap it out.
photo(21)
If the block is stripped i always remove them no matter what as dirt can get caught under them, very important to do so when dealing with spun bearing engines so you can get the rifle cleaner rods inside for scrubbing.
Now i tapped it out, but now the problem is that it was a original with check valve 1.5mm~? I've heard it were 2mm on rb25 s1 block thats why i thought someone putted down tomei restrictors.
Now my new question is that, Do i need to have the original with 1 way check valve or can i just run with the new 1.1mm? Is there any check valve in the fuel pump?
Now i tapped it out, but now the problem is that it was a original with check valve 1.5mm~? I've heard it were 2mm on rb25 s1 block thats why i thought someone putted down tomei restrictors before.
Fuel pump? You mean oil pump, yes? Yes of course there's a check valve in the oil pump, but that doesn't stop oil falling out of the head feed galleries.
But you're talking about a Neo head now anyway, so you don't need to pump up lifters quickly, so a 1 second wait for oil pressure won't be killing you, surely.
  • Like 1
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
