HI guys and girls.
I have up for sale is my r34 Sedan GTT 2000 s2 model skyline.
145xxxx kms, Sports Auto
Trust turbo back exhaust
Splitfire coilpacks
Bilstien front shocks
Kings springs
Greedy EBC
Turbo timer - wired into the black wire allarm
Alpine dvd double din head unit
Defi gauges (water temp, Boost & oil pressure)
Alpine amps
Eclipse 10" subs
Focal speakers
Screens in the headrests
Opitma Gel battery
18" rims
car is registered till late july.
$10000 ONO
you can contact me thru email.
[email protected]
https://www.sau.com.au/forums/topic/457837-r34-sedan-gtt/
  • 3 weeks later...
  • 4 months later...
car is still for sale.
open to reasonable offers.
Just had the water pump/ timing belts done.
I do not get much off a chance to login so if interested shot me a txt and i will answer any questions that you might have.
0409942069, shift worker so i do not answer phone.
https://www.sau.com.au/forums/topic/457837-r34-sedan-gtt/#findComment-7653432
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
