Hi again, I'm getting ready to have the cams I bought installed into the head (motors being built up as we speak) and I'm wanting some suggestions...
I bought a pair used from a member that were suppose to be 264 9.7 cams, but he sent me a 264 and a 256, 9.7, saying the other 264 was rust pitted.
So now I have a 264 and a 256. QUESTION: considering I'll be using my Electramotive TEC2 standalone, the CAS drive is not important to me, so which would you install where? (I forget which one has the CAS drive gear in it)
Like I said, I will not be installing the CAS mechanism, so either cam can go into either side... so which would be better where??
Thanks for the help
joel
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/
Hi Joel, I would go with 256 inlet and 264 exhaust, I have seen this (longer duration exhaust) work on a number of GTR's. What's the lift on each cam? My RB31DET has 268 inlet and 272 exhaust, both at 10.5mm lift.
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-932662
Thank You Sydneykid for the responce. The cams are both only 9.7 on the lift. I had the head set up on a end mill (for the lobe clearnce needed), and the notchs came out sweet ....
I also have the Tomie adj cam wheels to go with the cam upgrade, so if you would, please give me some advice on where to start with the placement of the cams.
thanks again
joel
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-932685
Duration is the amount of the time the valves are open for.
Lift is how far the valves open. Consider it as the washer in your tap; as you turn the tap on further, the washer lifts higher to let more water through. With the higher lift cams, the valves travel further into the the combustion chamber, thus the modification to the head is required for clearences.
As with longer duration cams, higher lift cams have their advantage in the higher rpm and hurt low rpm response. However, how much this rule effect the forced induction engines always puzzled me. Ben is running a huge turbo with crazy cams and has amazing response, does 400cc make that much difference...?
Back to you SK.
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-933140
thanks again
joel
Hi Joel, 256 @ 9.7mm and 264 @ 9.7mm is a good combination, if tuned properly it will make power and run very nice with that combo.
As for cam timing all engines are different, I start at 1-2 degrees advanced on the inlet timing and 3-4 degrees retarded on the exhaust. The exhaust timing makes the most obvious difference to the power, but don't ignore the inlet. It helps the response as well.
Hope that helps :thumbsup:
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-933161
SK,
Interesting that you've found that shorter duration inlet cam works better than the reverse!
Tomei sell two PONCAM setups for the RB26:
Type A - 260 degree, 9.15mm lift intake / 252 degree, 9.15mm lift exhaust
Type B - 260 degree, 9.15mm lift intake / 260 degree, 9.15mm lift exhaust
I went for the Type B set for my car, but was wondering what the theory behind running a larger duration exhaust cam was?
Wouldn't it be best to have a longer duration intake cam to fill the cylinder and push out the gasses out of the exhaust valves as opposed to having a longer duration exhaust cam and relying on scavenging vacuum to suck out the gasses?
Hmmmm...
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-933302
SK, Interesting that you've found that shorter duration inlet cam works better than the reverse!
Hmmmm...
Hi Merli, I didn't really specifically choose the cams, they were available at the time at right price. I was really more interested in the higher lift (and lower price), than the small diff in duration. :cooldance
I have heard and read that longer duration inlet is better for the reasons you put. And they certainly sound valid. I have also heard and read that longer duration exhaust is better, based on the fact that the inlet is under direct boost and the exhaust isn't. So you have to run longer duration on the exhaust to match. I have also heard and read that a longer duration inlet cam makes the engine lumpy, so its not a matter of running a LONGER exhaust duration, but in fact running a SHORTER inlet duration. :confused:
There are plenty of arguments either way, I really have no idea which is correct as I haven't done or seen a proper comparison. I suspect that there may be a boost threshold where the longer inlet duration argument has substance. But I have no proof, it's just a suspicion. :headspin:
Most of the engines I am involved with, I suggest the same duration for both inlet and exhaust cams. Maybe that's the right answer. ;)
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-934655
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end a made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
    • As someone who has pineapples, and horrible axle tramp... should I change these to collars? Is that what you're saying here? Why did you choose these instead of getting pineapples where you said you had good experiences of? I'd love to even attempt to get rid of axle tramp, I either get complete bogginess or absolute insane wheelspin, anything even remotely in between results in filling-removal axle tramp, to the point where launching the car is just not something I do.
    • Lucky for that, because putting ethanol in fuel only lowers the bulk cost of fuel if it's in 91 Add it to 98, 85% of it even and it quintuples in price. Strange physics. f**k you United, Gouging c***ts.
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
