Nothing on the inside as far as I remember. Just two 10mm bolts on the inside near the rubber seal and one or two clips on the outside that need a firm tug. Not too hard though you don't want to damage the wiring harness.
Went thru a lot of this chasing my bros dodgy tail light bulbs
They are a sod to get out. Take the two bolts out. You can see them when you lift the tailgate. The assembly can then be prised out with a BIG screwdriver. The assembly is located by two "pins" The upper pin is a push fit into the body, but the lower one is about 6mm dia. and is knurled so it is a bloody tight fit. Be patient and it will come out.
