So I got my Nistune done a couple days ago, spent about 3 hours on the dyno.
My mods
-blitz intake
-blitz front mount
-blitz front pipe
-blitz cat back
-blitz SBC
-no cat (test pipe)
-splitfire coils
-stock turbo
When we did some load pulls on the actual road the car blew off a vacuum line on the manifold. We fixed this leak and all seemed good.
At idle the car reads -19 vacuum, and on decel off the pedal i get -23 vacuum ....the car is tuned for a max of 13.5lbs of boost, but I turn it down to around 12lbs boost.
I ran into an issue the other day that anytime around 4000rpm in 3rd, 4th, or 5th the car would completely loose power. I can creep into 12psi by using partial throttle but full throttle and the car cuts.
So today I take it back and they boost leak test the car, do some smoke to help find the problem but not much luck. Then we take a look at the stock bov, we T into the vacuum line running from the manifold to the bov, and un hook the recirc side of the bov that goes into the intake tube. Apply some air and the BOV starts leaking like crazy, and there is maybe 2-3psi running through it.
Its evident the BOV needs replacing, but what gets me is why the car runs well still and how it can even make any boost with the BOV not being able to hold any pressure and leaking like that.....would it be because the turbo is compensating and spinning even faster to achieve its target boost level?
Lube the inner shaft of the bov with a tiny bit of moly grease, take the unit completely off, remember the orientation of the gasket. apply the grease to the shaft, then with your thumb push down on the bottom of the valve whilst sucking on the tube that connects to the manifold, and work the valve back and forth a few times. When I installed my hiflowed turbo I also discovered my 25 year old bov was leaking, but as it looked to be in mint condition I tried this as a last resort, glad I did! Pressure test it again and it now holds 20psi with ease.
I'm going to go with an upgraded turbosmart plumb back bov, want to keep the stock recirculating design.
But that's a good idea with what to do to the stock bov, kind of brings it back to life.
And yes I know the stock bov does let some pressure past, but no pressure would build up at all, it flowed right through....
Yeh, I used to grub screw the stock ones, but they are getting too old now, and the Turbosmart product works better without farting.
farting? haha
mine will flutter a little a low rpm, and is almost silent above 3500rpm
Ive tested stock bov blocked and open and it made no difference in boost level on the dyno
I found the difference to be in the on-off throttle responsiveness, rather than outright power, with blocked obviously giving the best response and making the throttle more 'twitchy'.
Ive tested stock bov blocked and open and it made no difference in boost level on the dyno. Check its vacuum plumbing, must be sourced behind throttle body.
Some cars it will definitely make a difference. I notice a few psi usually on the Stagea. It's a 4mm hole, it can't leak that much air back to the compressor, but the more boost, the more escapes, and the faster the turbo shaft needs to spin to counteract it. Why would you ever want it there? For drivability only.
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
