yea the guy just seems to try to hard. His GTR is pretty much stock. It's like since he is one of the "firsts" (in a sense) to have one in the USA, that he is trying to capitalize on the "coolness" before it dies. Not to mention, he has a small bit of "following" with car media. Have you seen the one where he goes through the drive through in reverse? Guy is kind of a ricer.
Edited by JTCC
https://www.sau.com.au/forums/topic/457898-for-gtr-fans/#findComment-7567742
Ah, will I or won't I post this? Google keeps feeding me this info; not so relevant to my own cause, but this one is local, and after a search I haven't come up with anything directly related ... so I will
http://www.gtspirit.com/2015/07/19/1000hp-lightning-yellow-nissan-gt-r-skyline-v-spec/
https://www.sau.com.au/forums/topic/457898-for-gtr-fans/#findComment-7570019
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
