What's up guys, I have been having some really serious issues with my build. I recently redid my engine and my ignition timing is way off. I have done the mechanical timing over 6 times now and each time I have done it I have rotated the engine several times to make sure the crank and cam marks line up, they always do, dead on. When the ignition timing is done the most I can get out of it is 15 degrees BTDC. When I remove the front cover with the RB logo on it, I'm able to adjust the timing to 20 degrees BTDC, but then CAS is not centered and I have very little adjustment left. I have Tomei procams, 260 duration, 10.80mm lift with adjustable cam gears. Yes, I have tried searching but I have not been able to find anyone with a similar problem to mine. The only information I have been able to get is I read somewhere that if my CAS is turned all the way advance then I'm doing something wrong, the thing is I don't know what I could be possibly doing wrong. The motor is swapped into a Nissan 240sx, and that is the one major issue I've been having with the car. I appreciate any suggestions, thanks.
https://www.sau.com.au/forums/topic/457906-timing-issues/
Nope, not stock ecu but I can get my hands on one, I used both methods to check the timing and they both give the same results. I noticed something else this morning, the exhaust cam bolts are rubbing on the inside of the cas. I think the rubber cas seal that I have is the wrong one, it has no metal where the cas bolt would go, I was trying to post a link that has a similar one to mine but this thing is not allowing me to paste, I'll take pictures tomorrow.
https://www.sau.com.au/forums/topic/457906-timing-issues/#findComment-7560858
The "unplug TPS to lock 15 degrees timing" trick only works on stock ECUs. If you're running an aftermarket ECU it should have a way to lock the timing through the tuning software.
So if you're not running stock ECU then unplugging the TPS did nothing and your timing will be walking all over the place trying to maintain the desired idle speed.
https://www.sau.com.au/forums/topic/457906-timing-issues/#findComment-7561016
I thought 15BTDC was the "factory" timing figure? So, what's the problem? If you have adjustable cam gears, then any deviation from 0 offset is going to change where the CAS sits at the correct timing. So, what's the problem?
https://www.sau.com.au/forums/topic/457906-timing-issues/#findComment-7562493
I was told that the correct timing is 20 Deg BTDC, correct me if I'm wrong please. Everywhere I looked while researching said the same thing. I have played around with the adjustable gears and that has not had any effect on the cas position which seems a little odd to me. Also the cams have been degreed. I found out that I bought the wrong cas gasket (seal, whatever they call it), hence the reason for the bolts rubbing.The car will start, idle and shuts off after about 7 to 10 mins of idling. Once it shuts off it wont start again. Also if I blip the gas pedal while it is idling it goes past the idle speed and shuts off and once that happens it will not start. I have checked and cleaned the iaac valve, changed it and still having this problem. I checked the coolant temp sensor and it is ok. There are times when the car will start idle and the af ratio will be 13.5 and then it leans out to 17, another time it gets pig rich. All this seems to me to be potentially a wiring issue so I'll be pulling the harness this weekend and I'll keep you guys updated.
https://www.sau.com.au/forums/topic/457906-timing-issues/#findComment-7564898
Rb26 is 20°btdc, rb20/25/30 are 15°btdc
what ecu are you using? Does it retain the air flow meter? cause it kinda sounds like it is on its way out
You didn't buy the wrong one, you need to take the metal rings out of the old gasket and put them in the new one
https://www.sau.com.au/forums/topic/457906-timing-issues/#findComment-7564909
Ok then yes it's 20°
I would say they over fueling and dying issue is you have a dicky airflow meter or an intercooler pipe that isn't sealing properly
You will need to get on to rhd and order the three metal spacers before continuing tho
https://www.sau.com.au/forums/topic/457906-timing-issues/#findComment-7564920
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
