Hey guys, I've got a r33 with an rb25det in it, following are the mods;
-splitfire coilpacks
-power fc
-FMIC
-3' turbo back exhaust
-Z32 afm
-570cc denso injectors
-walbro 255 fuel pump
-Hypergear ATR43SS-2 turbo waiting to be installed
-gizmo EBC
And probably a few more
Question is, im chasing about 270-280 with the new turbo and tune, however my tuner was saying the injectors might not be big enough and should upgrade a 460 fuel pump to mitigate the issue. Talked to a few other people and they said don't bother just upgrade injectors.
What does everyone reckon ? Upgrade fuel pump and keep and injectors and scrape by or just go bigger injectors, and if so, what size and brand ?
Thanks in advance for any help
https://www.sau.com.au/forums/topic/457915-injector-size/
The injectors are large enough. They will support over 300 rwkW. That is getting a bit close to the margin, so if you want some comfort then sure, upgrade. Your best bet would be Bosch EV14 based ones. Probably 1000cc would be the best choice. They'll be much better injectors than those nasty old school Denso ones anyway, so don't worry about them being too big.
The fuel pump will probably be fine. Too big a fuel pump causes unnecessary fuel heating - so it's not a free choice anyway.
https://www.sau.com.au/forums/topic/457915-injector-size/#findComment-7560423
  On 01/07/2015 at 1:03 PM, muzziak said:
Well this has just made the decision that much harder, tuner and mechanics saying go bigger. But thanks for the feed back guys
Well mine made 314AWKW with 550s and had plenty of room for more. Name the workshop that says you won't make 300 on 570's !! I reckon they will do 350 at least if not more.
However if you have money to burn stick some ID2000s in and you will not have to change them for a while.
https://www.sau.com.au/forums/topic/457915-injector-size/#findComment-7560643
570cc injectors at 80% duty cycle 1 bar of boost will make 324kw - ish on 98 , I recommend not going over 80% duty cycle, and more fuel is better than not enough. Your 255 fuel pump will be fine aswell. I wouldn't change anything.
Edited by skyline32sup
https://www.sau.com.au/forums/topic/457915-injector-size/#findComment-7562464
