Hey,
I have an R34 Gtt with Nismo S Tune shocks fitted all round and currently running Lenso D1R wheels all round which are 18x8.5 all round but not sure of the offset. Tyres are 235/40/18.
I've come across a staggered set to of Lmgt4's at a good price but not too sure about the staggered sizing look just yet? Does anyone else run similar set ups?
The fronts are 17x8.5 +30 front tyres are 225/40/17 and the rear is 18x9.5 +38 with 235/40/18 tyres.
How would this setup fit/ run and obviously look?
Any help would be appreciated!
Cheers
https://www.sau.com.au/forums/topic/457928-staggered-nismo-lmgt4-on-r34-gtt/
Front tyres are stretched onto rims that wide, so are infected with AIDS and will infect you too. If you do plan on using them you should go up to at least 235/45 if not 255/40.
Rears are also stretched onto rims that wide and will give you AIDS from behind. You don't want that. Unless you're into that kind of thing, of course.
And that's just dealing with the tyres. The different diameter thing is not my cup of tea.
  • Like 1
Thanks for the feedback guys!
34geeteetee thanks for the offer but if I do change my lensos it'll only be lmgt4's going on! I'm a bit of a Nismo whore.. Then again aren't we all? :P
The rims aren't on a 34 lol. They are on an old Toyota crown I believe? That's why I'm not sure about the offset suiting a GTT? To be honest I thought they would be stretched considering the rears are a whole inch wider then my current rims fitted with the same 235 width tyres.
I was thinking 235/45/17 tyres for the front. What about the rear? 255/40/18? Then would the rear guards need rolling?
Thanks guys
Hahaha Hadouken!
I'd be running 265's as well.. But whether they will scrub without rolling guards I don't know.. I was hesitant on the +38 offset but it seems Nismo recommend 18x9.5 +38 on the back with 255/35/18 tyres on the r33.. See below. But I can't find anything for a 34!!!
The offsets will fit especially if you stretch the tyres. I have the same (+33 on the front) on my R34 but mine are both 18's not 17's at front and 18's at rear.
Also my wheels are LMGT2's... so far as 'same' they aren't really. But the offsets are. I also have 275's on the back with no rolling nor flaring. I'd wager they can be made to fit even if they're slightly too big.
Yeah thanks Gtsboy, that's what I thought..
Of course kinkstaah, anything can be made to fit! :P I love the look of LMGT2's on 34's. Do you have a pic?
I also found this on the forum. Thanks to Shoujiki! Seems the offset is perfect.. Just going to need to get some new Michelin Pilot Sport 3's fitted!! :)
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
