Hey guys,
I have a r32 with an rb20det and an rb25 turbo. The turbo blew up and i replaced it with another rb25 turbo. Ever since replacing it the boost pressure wont limit itself. Anything over 3500-4000rpm causes the boost pressure to spike. It got to around 15 psi before i backed off to avoid damaging the turbo or other components. I have a turbosmart boost tee installed which was set to 12psi before swapping turbos and worked perfectly. After this issue i wound it right back to see if that was the issue but im still having the same problem.
Any ideas on what the problem would be?
EDIT: Sorry I just realised I posted in the wrong spot. Not sure how to delete.
Edited by Anthony9five
Well seeing as the waste gate Controls boost it would be wise to check you plumbed it up correctly.
What else could have changed?
Ill triple check that in the morning but im pretty sure its plumbed up correctly.
Thats what has me confused. Ive checked all the basic stuff and no luck. Im just hoping for ideas on things I may have missed.
What happens when the boost controller is removed wastegate is plumbed directly?
I haven't tried that yet as I don't have a length of pipe long enough. I'm not gonna rule that out, but the boost controller was working perfectly before the turbo swap. If i cant fix it ill buy some pipe and try that though
Are you sure your hoses are going into the correct ports on the solenoid?
Any pics?
Ill grab some pics in the morning.
The point is the wastegate may not even be opening sufficiently due to a physical obstruction or a problem with the actuator.
Could be a dodgy Watergate or possibly the flap is fouling on the dump pipe
How would i diagnose this? And then how would I fix it if it is the issue?
To diagnose the wastegate flap fouling you need to disconnect the wastegate and swing the flap to see if it opens.
I did this and the flap moves easily. Not fouling on anything.
Is the boost T the right way? They are a one way valve inside.
I can't tell if the boost source for the turbo actuator is coming from the BOV or not, it should come from the piping.
Yeah the boost tee is the right way. There is an arrow on it that has to be pointed towards the wastegate, which it is.
The boost source is coming from the piping not the BOV.
As has been said, try running the wastegate straight from the piping.
There is always the chance though that the wastegate itself is damaged. If you have a pump you could attach it to the line to the wastegate and see if it opens when pressure is applied (or if the diaphragm in the wastegate is damaged)
Kinugawa makes an actuator where you can replace the springs to suit the boost level you want to run.
I am using one on a hypergear turbo, although I had to make a new bracket in order to mount it to the turbo. Its supposed to fit a stock turbo though.
http://www.ebay.com.au/itm/Kinugawa-Adjustable-Turbo-Wastegate-Actuator-Nissan-Skyline-RB25DET-R33-/291501973534?pt=LH_DefaultDomain_15&hash=item43dedf201e
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
