Hi All,
So after a very long time away from Skylines and the club I have recently re-joined/newed my membership.
The last time I was a member was back in 2006/2007 during the early RB30DET building days (page 2 of the dyno results). Well back then I was younger and much more willing to let my impatience get in the way with a willingness to do things on the cheap. This ended up with a RB30DET that ran, but no where near the potential I desired. An extreme lack of budget was the deciding factor on modifications, maintenance and fuel.
So 10 years on I got married, completed some higher education (yet for some unknown masochistic reason I'm still doing this) and settled into a career. Since 2008 the old R33 has predominately sat waiting for me to return to it. I imported the car from Japan when I was 18 and knew it was never going to be sold despite some offers over the years. It has been started a few times here and there but mostly neglected.
For a few years I suppressed my car related desires with various "car" hobbies such as RC car racing, small event photography and large portions of iRacing (online simulated racing - Very good actually especially in a sim rig). These have not provided enough and my wife even noticed the change in my demeanor and said to me "your not going to get rid of it so do what you want with it".
Thus began the restoration plan :D
I have prepared most of what I can think of in an excel document with links to online stores and 95% of it is actual pricing rather than some unrealistic expectation of this being a cheap process. If anybody would be interested I have shared this and would appreciate feedback. A whole lot has changed since back then and I have fully abused the search feature to construct the proposed build. The goal ultimately is to build "my supercar".
Currently getting around in my Focus XR5 that I just love, a great car that is not outstanding at any one thing but just heaps of fun in most. I hope to attend a few club events with it.
Goal is for a 600HP street car, but I will be very happy with anything 500+. A weekend toy set up with reliable/proven parts and able to be taken to any style of event for some fun. Not in a rush in anyway what so ever, currently thinking this will be a 2 year build. I have lots of other ideas but I hate to think how bored you may be now reading this.
Thank you for reading and I hope to hear your feedback.
Cheers
Skyline1.xlsx
  • Like 1
https://www.sau.com.au/forums/topic/457936-returning-member-saying-hi/
  • 2 months later...
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
