I don't think this topic has been discussed much at all on SAU.
I know a few people on SAU use trickle chargers. This will be a first for me.
I bought myself a Trickle charger from Jaycar, but have been given advice that I need to disconnect the battery from the car so that I don't ruin the Alternator or other electronics if there is a current surge from 240V.
A few questions I have.
1. Owning an R34 GTR, where the battery in the boot, it's not very well ventilated. Are people removing their batteries from the car? Kind of defeats the purpose of a quick solution.
2. The car only gets taken out on weekends. Am i better off simply disconnecting the -ve terminal for the week? Have i wasted my $$$ on the charger?
What other tips do people have when using a Trickle charger?
https://www.sau.com.au/forums/topic/457967-using-trickle-chargers/
I do this,
Disconnect +Ve side on the battery and leave it. It has been fine for me for up 6 months.
When I come back from lengthy times away, I put the car on the trickle over night and that is perfect.
With the +ve side disconnected instead of the -ve I don't see how there can be a problem with sending a surge through the car....
Given that there is a 20:1 step-down in the charger (240V input, 12V or so output) there would need to be a huge input voltage surge to damage any car electronics. Do you have a surge arrester in your meter box - a big enough surge to damage anything in the car will also take out most of your house electronics.
I use a 1 amp trickle charger on a motorbike, but I run it off a timer so it's only on for an hour each day. This helps prevent over-charging the battery. Have done this for many years and battery life has been great.
My experience is using a Trickle charger is fine.
In my case If I disconnect the battery the mongoose alarm goes off.
So I leave both terminals connected while charging.
Generally only connect it up if I'm leaving the GTR in situ for over a few weeks.
Having it on a timer is a brilliant idea. Might give that a go. The charger i got is:
http://www.jaycar.com.au/PRODUCTS/Power-Products-Electrical/Charging/SLA-GEL-Chargers/6V-%26-12V-Heavy-Duty-8A-Car-Battery-Charger-with-Trickle-Charge/p/MB3522
I guess my main issue is that the car is kept in a downstairs garage (unit block) and I don't want to come home to an inferno. I understand that most batteries when on charge can emit gasses, which could cause a fire.
If anyone has seen the battery location on a 34R, it's an enclosed, tight space with a tonne of carpet surrounding metal
The whole idea of trickle charging is to leave the charger on the battery constantly. I don't like charging at high voltage/current with the battery connected in the car, but trickle charging should be fine.
When you are driving the car the alternator is charging the battery, so there should be no difference really
The BNR34 has charging terminals in the front under the fuse box.
The main possible problem is reversing polarity (by accident).
If you're so concerned about surges from lightning strikes just put a surge protector between the trickle charger and the power point the same way you protect your computer.
Learn something new everyday. Did not know that. Makes it a hell of a lot easier if this is the case
  • Like 1
Lol, look at the fuse box and you will see a (+) and a (-) each next to a metal tab. Surely you didnt think that if you wanted to jump start your car that they would make you do it in the boot...
ok ok, geez, chill out man.
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
    • I love it aye. The ability to switch to RWD on the fly can be handy for certain situations.... I can adjust the dial to reduce oversteer out of the corners. I've noticed I can be on the power earlier out of corners and it feels like its on rails compared to the factory system. The factory system would be a bit slow out of the corners and give oversteer. And if you don't like that it is super easy to adjust the front wheel bias.  I would definitely recommend the unit for someone who is looking to have a tunable 4WD, It can be set much more aggressive than factory. And being able to turn off 4WD with a switch has some benefits.
    • Damn this looks so good. I wanna catch the punks who touched the car. That made me angry.
