I have the Century CC1206 12V 1/3/6Amp 9 Stage Battery Charger. It is different from the one you linked but I don't know in what way.
Their manual says that it both can be left on 24/7 and that it shouldn't be left on 24/7. Go figure ¯\_(ツ)_/¯
Quote
Can be left on 24/7 to ensure your battery is always maintained and fully charged: The battery charger can be left permanently connected all year round. The intelligent charger will monitor the battery voltage and will maintain it at peak performance with a special pulse charge during long term maintenance. Please note that even if the battery charger incorporates this feature, Century Batteries does not recommend leaving the battery charger connected 24/7.
I haven't been game to leave it on there for more than 2 days.
  • Thanks 1
I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features
- choose battery chemistry other than lead acid (most of mine are AGM)
- power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected
https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr
The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future.
The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
  • Thanks 1
At work we've got a smaller version of the Projecta that Duncan posted above.
At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU.
ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode.
I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. :) that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
  • Like 1
I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
One of my concerns initially was if something catches fire somehow.
2 hours ago, Murray_Calavera said:
Same.
It's depressing to say this but the skyline can go months on the charger between drives.
Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
