Unbeknows to me, and others, there are TWO switches under the dash that control the on off operation of the lights. One is easy to see and that one tested AOK. Hence the dilema about what was wrong.
Anyway my R32 son went upsidedown with his legs over the back of the drivers seat, and lo and behold there is another switch.
Now there was missing a rubber buffer so the switch could not break the circuit and turn the lights off. Put a packing piece in and "viola"! lights out.
So if you ever have this problem, takes two to turn the lights out.
https://www.sau.com.au/forums/topic/457975-stop-lights-are-off/
Because it is auto is the reason there are two switches. One for the brakes and one to let you engage the gear box when the brake pedal is engaged.
It is that simple.
R32 who works for Hyundai has only worked on Hyundai and the actuator is in the box itself that is why we did not look past the original switch that is the auto box sensor. The brake light switch is difficult to see unless you are upside down with your head up your ass.LOL
Will get some pics today and post up.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
