Hi All,
i have a 19incher wheels and running kumho Le sport KU39 245/35/19, i find that every 5k kms i have to realign my tyres as around 5000 kms it start to make that out of alignment noise.
Is this common?
should i increase my profile to 40series next time to lessen the frequency of alignment?
thanks
JT
https://www.sau.com.au/forums/topic/457982-wheelstyre-noise/
I had no idea you could hear when your tyres were out of alignment.
And sure. Run some 40 series tyres. Because, you know, that would be way closer to rolling diameter of stock wheels. Even the current profile is good and I bet your speedo isn't off or anything.
  On 04/07/2015 at 2:48 PM, The Max said:
I'd say you're hearing the noise because it's pretty average rubber you have there. Once I got rid of my Kumho KU31s and replaced them with Michelin Pilot Sport 3 tyres, no more screeching around bends.
ok something to think about next time around..i though the le sports were pretty high end of the kumhos..
In my experience and very humble electrical engineer's opinion (i.e. I have no expertise in the field of tyres), Kumho don't produce anything high end when it comes to road tyres.
The KU36s I had were one of the best tyres I have used for grip and feedback, pitty they are insanely noisy. Not suitable for a daily IMHO, unless you have a car with a lot of sound insulation.
I have had KU19s too, and they were quite poor all round.
Hi Ben,
can you be a bit more specific? do you think its my driving style or the amount of times i hit pott holes? lolz
or could my cheap rims could be causing this? i have kings malice
  On 05/07/2015 at 3:26 AM, Ben C34 said:
If the alignment is changing that's the cars fault, not the tyres.
ok apart from michelins and pirelli's do you have other experience with other brands that are a little cheaper than them two? hehe
He has KU39 not KU36. Kumho aren't the 'best', they are a good low-mid-range tyre. They aren't that quite either. My Subaru came with KU22 and they were quite noisy, changed to Momo M3, quieter and grippier, but can go more quiet (will next round of tyres, gonna get Michelin).
OP, you may have some worn bushes?
Ok bought the car with 35k kms. i've done 75k now. tyres and wheels have done 16k kms. so you think time to go take it to pedders?
:) I wouldn't take box trailer to pedders.. But maybe some franchises are better than others..
I have had many good experiences with the local fulcrum suspension outlet, but I am not sure if they are in all locations.
As for the KU36, I know the op had 39s, I was just pointing out they do make a good tyre, if you can ignore the noise. A friend at work uses them on his turbo rx3 track car.. Where noise isn't exactly a problem.
But their 'mid range' tyres are quite ordinary.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
