Up for sale is my ATI 1000hp balancer.
Condition is pretty much brand new as it was fitted to the engine once but was then removed as I'm going to a crank trigger set up. The engine has never been started.
Comes with everything that's with a brand new balancer inc water pump pulley, stickers and instructions.
Chasing 650 which is reasonable considering the price of Aus retailers and the cost of importing from the USA with the dollar the way it is.
Located Sydney and will post
0432528844
Cheers
https://www.sau.com.au/forums/topic/457983-fs-r3334-rb26-1000hp-ati-balancer/
Forgot to mention that the balancer comes with provisions for a dry sump mandrel
Do have pics on request
More info
ATI Super Damper Harmonic Crank Pulley for R33 and R34 RB26DETT. This truely balanced crank pulley was made to eliminate torsional crankshaft vibrations caused by abnormal wear. It is a direct replacement for the OEM crank pulley. Made to exceed SFI 18.1 Specs with laser engraved timing marks. The ATI Super Damper is also coated with black zinc chromate to prevent rust and reduce wear.
The Super Damper does not retain stock belt size. You will need to measure for the correct belt size.
Damper includes new aluminum water pump pulley for clearance. A/C belt is a 25% overdrive - DO NOT USE BELT IF RACING! 15% underdrive on power steering, OEM size on water pump.
Approximate weight of the pulley itself is about 11 lbs, good for 600-1000HP.
