How much can I increase my boost too before having to make modifications to the turbo?
You might wana keep it around 11-12, for more reasons than just the turbo's life.
To avoid detonation, and keep the turbo efficient most people tend to keep it round there. With correct tuning you can get alot of power out of them on low boost with a SAFC or similar.
https://www.sau.com.au/forums/topic/45799-how-much-boost/#findComment-931553
agreed.
i think the general consensus is that @ 14psi you are pushing not only the flow capacity of the turbo, but also the life of the exhaust wheel
people generally run around 12psi feeling that this offers the best power for turbo reliability
(also, a search would yield quite a few threads on this matter)
Waz.
https://www.sau.com.au/forums/topic/45799-how-much-boost/#findComment-931590
i use to run 12 psi on my r32 rb20 ... i end up changing the turbo 3 times ... and the last one was leaking .... :D ...  that was befor my friend crash the car.. :thumbsup:
i think 10 is ok ...  but am planning for 12 on my r34 ... :D
you blew the turbo 3 times on the standard set up? Im thinking your boostguage was faulty and you were running significantly more than that...
https://www.sau.com.au/forums/topic/45799-how-much-boost/#findComment-933177
no my boostguage was perfect ... my car was standerd ... only for the KSROM chip
which is set up for 12 psi ( i dont have a boost control ) .. and 8000 rev ( they did it is japan) and some fuel and ignition remaping ...
and 3.5 inch exust ..
no cat no nothing .. but the muffler at the end .. thats why my turbo exust wheel spen all the way out of the exust .. lool ... :cheers:
maybe from the way i was driving ... lol .. drifting all the time .. and the rev was always high ... above 3500 .. :rofl:
any way ... its over ... i have my r34 now ... never reach 3000 RPM :jk: lol
some pic of the turbo ... with something missin :)
https://www.sau.com.au/forums/topic/45799-how-much-boost/#findComment-934416
lol good effort, im not sure how the hell you managed to kill 3 on standard boost but thats pretty special dude lol
Take it easy on the 34, those turbos cost a wee bit more. I guess you could buy in bulk? lol
Cheers
loooooooool ... dont wory about my r34 ... i'll be changing the turbo soooooon :P
https://www.sau.com.au/forums/topic/45799-how-much-boost/#findComment-936416
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
