Hi all
I'm installing a hks gt-rs turbo on my r34 GTT. Read that I should prime it before I drive and to do that I need to cut the fuel supply or ignition. Could anyone recommend which I should do? Would I just remove a fuse and if so does anyone know which one? Also if anyone has any tips like pouring oil directly into the turbo before etc feel free to share! :)
Cheers
https://www.sau.com.au/forums/topic/458006-turbo-install-cut-fuel-or-ignition/
Seriously people build engines without worrying about it, within a second or 2 of starting your whole engine gets oil pressure, some just squirt some oil in before fitting the oil line on.
If you want to sit there cranking it, remove the spark plugs to make cranking easy and it automatically kills spark and kicks out any injected fuel out through the plug holes.
Yeah that's what I've read, but I've also read that you could potentially kill a turbo in the first few seconds so I'd rather not risk it
Also I'm running a return flow fmic so there's all the piping above the spark plugs and I'd really like to do that as a last resort considering that'll take an hour or so to remove everything and re torque the plugs along with trying to fit that darn bitch of a pipe back up to the plenum inlet and fmic joint
No one has ever killed a turbo with oil starvation at first start up. If that actually happened it would have been a DOA turbo anyway.
When you do an oil change and fit a dry filter the whole engine runs with no oil pressure for 4-6 seconds
I put a capful of oil into the turbo itself once installed (into the oil inlet hole, to be specific, eg don't go pouring it into the compressor outlet), then put on the oilfeed line. I usually change the oil whenever installing a new turbo too, and crank the engine till oil pressure light goes off (if you have an immobiliser fitted you don't need to pull any fuses etc, it already won't start), then start her up. Drive normally till at operating temperature, then turn car off, go inside and play Street Fighter 2 Hyper edition on SNES, and let car cool down completely. My theory on that being let seals/bearings etc reach operating temperature before being subject to excessive load, and then all settle into place as they cool down, after going through a heat cycle. Maybe not needed but I've never had any turbo issues, they have all lasted 30,000 years doing it that way.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
