Turbo Install, Cut Fuel Or Ignition?
Hi all
I'm installing a hks gt-rs turbo on my r34 GTT. Read that I should prime it before I drive and to do that I need to cut the fuel supply or ignition. Could anyone recommend which I should do? Would I just remove a fuse and if so does anyone know which one? Also if anyone has any tips like pouring oil directly into the turbo before etc feel free to share! :)
Cheers
Seriously people build engines without worrying about it, within a second or 2 of starting your whole engine gets oil pressure, some just squirt some oil in before fitting the oil line on.
If you want to sit there cranking it, remove the spark plugs to make cranking easy and it automatically kills spark and kicks out any injected fuel out through the plug holes.
Yeah that's what I've read, but I've also read that you could potentially kill a turbo in the first few seconds so I'd rather not risk it
Also I'm running a return flow fmic so there's all the piping above the spark plugs and I'd really like to do that as a last resort considering that'll take an hour or so to remove everything and re torque the plugs along with trying to fit that darn bitch of a pipe back up to the plenum inlet and fmic joint
No one has ever killed a turbo with oil starvation at first start up. If that actually happened it would have been a DOA turbo anyway.
When you do an oil change and fit a dry filter the whole engine runs with no oil pressure for 4-6 seconds
I put a capful of oil into the turbo itself once installed (into the oil inlet hole, to be specific, eg don't go pouring it into the compressor outlet), then put on the oilfeed line. I usually change the oil whenever installing a new turbo too, and crank the engine till oil pressure light goes off (if you have an immobiliser fitted you don't need to pull any fuses etc, it already won't start), then start her up. Drive normally till at operating temperature, then turn car off, go inside and play Street Fighter 2 Hyper edition on SNES, and let car cool down completely. My theory on that being let seals/bearings etc reach operating temperature before being subject to excessive load, and then all settle into place as they cool down, after going through a heat cycle. Maybe not needed but I've never had any turbo issues, they have all lasted 30,000 years doing it that way.
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
