Hi all
I've finally got around to installing my hks gtrs turbo on my GTT and I'm unsure of which ports in it are oil feed and water feed and drain. Could anyone please confirm which ports these are?
Also if anyone could confirm which ports are oil and water feed on my engine block/bay that would also be greatly appreciated :)
Cheers
post-135000-0-31184300-1436118101_thumb.jpgpost-135000-0-61008000-1436118220_thumb.jpgpost-135000-0-68693700-1436118307_thumb.jpg
Hmm.
I'll be nice.
There are 2 water ports.
There is one drain.
There is one oil inlet.
The drain is larger than the inlet. You can even look at your old turbo as they are the same oil and water setup.
Good luck.
Sorry I'm fully aware that there's both a water feed and drain and oil feed and drain (I'm not that dumb). It's obvious which one the oil drain is but I'm not 100% sure which the other 3 are as there are no markings or diagrams I can find on the internet. Just asking on here for clarification as I don't want to destroy a hks turbo from getting the oil and water feeds mixed up. I posted that at 1:30 in the morning so sorry for not making myself clear
Looking at the turbo again on the top and bottom are 2 thicker lines
And on the sides are 1 smaller line and the oil drain
Safe to assume the smaller one is the oil feed and the thicker line at the top is water feed ?
It gonna sound harsh but if you cant figure that out you should think twice about your ability to fit it properly... anyone can bolt things together but if you dont understand why it often runs into issues later on.
  • Like 1
Sorry I posted this asking for confirmation as I thought someone would know. Would like to be 100 % sure about something before I do it to my car, not. 99%. I've figured out the oil feed and just want to makes sure I don't mix up the water ones
Also I'm referring to the positioning of the inlets in respect to the pictures that I uploaded. When I say top I'm referring to the inlet at the top of the photo etc. thought what I was saying was pretty straight forward ..
Was just trying to sort out which is the inlet and outlet for water as I thought it had to go in a specific way but it's all sorted now. Found out it's dependent on the angle of the turbo and nothing to do with the internals or anything
It's not really even dependent on the angle of the turbo. Given that the oil definitely has a top and a bottom (ie, drain on the bottom) that means that the water definitely is located on each side. Sure, if the turbo is cocked over on an angle then one water connection will be higher than the other.....but there's little enough difference in that height to justify saying that one or the other must be the inlet. A hot turbo will thermosiphon forwards or backwards just as happily once the engine is shut off, and it hardly matters if the water is going the normal direction or the opposite direction under those circumstances.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
