Looking for a torsen diff/centre from a series 2 R34 GTT, or a 1.5 way diff/centre to suit an R34 GTT
Will pay up to $400 for a compete torsen diff.
Can pickup within a few hundred km's of Sydney
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
