Ok first a bit of history
I bought the car in 2003 it came with the usual exhaust and pods and beyond that was pretty much standard, i replaced the fuel pump and had the factory ecu remapped and made a respectable at the time 235kw at the wheels
In 2004 I sold the car and stayed in contact with the new owner, come easter 2007 the owner decided he wanted to part with it and after a check over the deal was done.
Over the next few years it stayed basically mechanically the same but got fitted with a set of r33 brembos and a new set of wheels DSCN0097.jpg
In 2011 the engine finally let go and after dramas with the engine builder I lost interest in the car and it sat outside, untouched for about 3 or so years. Eventually I bought and fitted a stock r33 engine, removed the hicas and fitted another set of wheels BE45199B-21D6-4332-A0D8-DFF69E14B8B2-334
So here we are today and I've finally decided to do a build but won't be anywhere near as big as the previous one was. The goal for this build is to make 373kw (500hp) at the wheels with as close to standard response as possible
Now on to the build
First things first after sitting around for so long, with my little helper I replaced all the oils in the car 38715BAD-0206-4564-8071-EAA643FC9322.jpg
Then took it up to jez for a baseline run so that we know where I'm starting from and know how far I need to go8DDD7264-F675-4601-8890-6964AD4070D8.jpg
So here we are with the baseline and a plan in place that I will reveal as the build continues
  • Like 5
https://www.sau.com.au/forums/topic/458011-r32-gtr-long-term-love-now-project/
I'm going to try and keep the updates weekly in order to stop the thread/build going stale, not everything will be a performance upgrade, there will be some general refreshing and tidying up as well. But there will be photos and information of everything that gets done along the way
This won't be a do everything in one hit build, it's also not going to be a slap a bunch of crap together and hope for the best. It's going to be a very thought out and have a few things a lot of people either wouldn't do or wouldn't think of
TBH it's very hard to find info on E85 and -7's.
i just said stuff it and we will find out. Tuner thinks 350-360 on E85 and they will run out of puff. Will report back when she is finally fixed though. Can't wait to see what you will do man!
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
