The parts I need to fix the oil leaks have finally arrived and I can start moving forward with the project again
In there is the speedo drive o-ring and seal and also a new power steering hose, will be fitting them as soon as I get some time (hopefully this week) and get the car back on the ground to get that exhaust sorted out
Awesome project so far mate. Look forward to your posts!
thanks mate, unfortunately at the moment it's little job that must be done before I can get back into the bigger jobs
Friday I fitted the power steering hose and the seals for the speedo drive, but for the awd piston in the back of the box there is no seal,
So I pulled it out and ran a bead of sealant around it and put it back in
I then filled the fluids back up and started the car to bleed the power steering and left it up on the stands. Im going away for a week so will leave it up there and check for any signs of leaks when I get home, it should all be good and I can move onto other things
I'm back from my holiday and went out to the garage cause the car was left on the stands and its dry under there, so the oil leaks are all fixed and I can move on
While I had it in the air I knew it required new castor rods cause it would squirm under brakes and really didn't feel safe at all. I had a set sitting around from a front cut I had years ago, they aren't damaged at all and decided to throw them on. 41580F8E-B3BF-4FF4-9969-68C1691B18AE.jpg That's a photo of the old ones showing how flogged out they were
A8D99E18-CF3A-497E-A3A1-37456936598E.jpg And the replacements now in the car :)
  • 1 month later...
Woke up this morning to the post man dropping something off and I ended up with this box
Was very happy cause I knew what was inside of it
B664247D-CCE5-442A-9B91-F8C545ADE0D4.jpg It's was my 2x3>3.5in midori front pipes and the final piece I needed for my new exhaust and after all this wait here is what I've gone with
It's midori front pipes, venom 3.5in 100cpi cat and a kakimoto 3.5in stainless cat back. Now being a typical Japanese exhaust the center muffler is actually only 3in, so I bought a magna flow muffler to replace it and ensure the whole exhaust it 3.5in
  • Like 5
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
