2 hours ago, admS15 said:
Which is why 8374 makes sense. Isn't that right Grant??
Na, twin EFR's is better.
Cos it's one more than one hey Bill?
  • Like 1
2 hours ago, r32-25t said:
That kit is far to untidy,
Wrap the bonnet with a photo of stock engine bay, that way you'll look at it and say "that's tidy engine bay" :P
Sent the rocker cover out to craved coatings and got it done to match the rest of them IMG_4744.thumb.JPG.6afa6134301a3d4fee17e346f645c60a.JPGam going to uncover the writing on it due to the candy looking different there compared to the rest
  • Like 1
Did some work on it over the weekend, fist pulled the timing belt off and inlet cam cover off
and new cam in for clearence measuringIMG_4811.thumb.JPG.d6fef983e41a59b5e176ea8d2d79bc1e.JPG
6 of the clearances are out of spec and the shims have been ordered and should hopefully be here in the next couple of days
  • Like 1
Parts are back from ceramic coating IMG_4822.thumb.JPG.5cf3f8ee475476153faf90d50043a1e0.JPGi also bought plugs for the original oxygen sensors because I no longer use them and they will just be in the way when installing the turbos
  • Like 3
Had a couple of hours over the weekend to work on itIMG_4827.thumb.JPG.3af7f04e2cb1aed102f7d208a5971def.JPGthe shims had arrived a few days before an i fitted them, checked the clearances were spot on
IMG_4828.thumb.JPG.3db9bfcd9c9a8326e7ccd08c1287e64e.JPGthen moved onto the cam gears and timing belt
  • Like 3
I then grabbed a die grander with basically a scotch bright pad on it and attacked the powder coatIMG_4833.thumb.JPG.7f2c88345b2389c350619f4fe737f249.JPG halfway done
IMG_4834.thumb.JPG.2353981157b2bd15f90050fd90bca345.JPGpowder coat gone and then I ran another pad over it to give it a machined look
IMG_4835.thumb.JPG.7c791d0e52471563868b131866efcdd9.JPGand the finished product
  • Like 1
Then got to fitting it to the engine IMG_4836.thumb.JPG.04867ea540bf3c0762a2b3f6934ce1f5.JPGhere it is fitted to the engine
IMG_4837.thumb.JPG.df0c7aade7b3e1f6dac59e3e349b01ce.JPGthis comes with the kit and of corse is the reason the kits costs so much lol
IMG_4838.thumb.JPG.a9df0418147d17669701275a29de6702.JPGand with all the sensors and oil cap fitted,
Had some time today so I decided to spend it playing with the car IMG_4822.thumb.JPG.d009be87cb63945f4e5725c08b67dc90.JPGIMG_4844.thumb.JPG.5f6d12c7e23b38252856bef4d6e73724.JPGfinally unwrapped all the parts I got ceramic coated, it's a shame you won't see them once they're installed
And finally the turbos can start going on, some people will be a bit disappointed IMG_4824.thumb.JPG.28e6ae604b5f998129b74c4849a2e97a.JPGIMG_4823.thumb.JPG.f5c51bbaee14e0635d24ed4146f4b0bc.JPGbut I'm staying twins (that was never a secret) and they are nothing specialIMG_4825.thumb.JPG.b6560843efd7188c06aba5905a80ef37.JPGjust a basic set of -5s with very low kms that I got for a price way to good to pass up
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
