Got a couple of videos from the roll racing, unfortunately the GoPro video was all ruined so these are just off people’s phones
this one i stuffed the start but made up for it
 and this one I finally got the start right against another r32 Gtr
A problem I had with roll racing was my passengers kept asking how fast we were going and my reply was always “I don’t know but it was more then 180”
76B0D5D7-535E-46CD-8E41-37F9CCDA56BA.thumb.jpeg.de3766cf8fe7afc1b9f6e065f7ffc0d7.jpegso out came the instrument cluster
FFF156AE-6CA3-43CD-9E75-51B1D70C8852.thumb.jpeg.97935327da454bc08e97fc08736fab46.jpegand I found a nismo one for sale on here but it was the newer style dash (blue circuit) and it had an extra 34,000kms compared to mine
  • Like 3
So I pulled out the speedo swapped over the speed sensor that’s in the back and flicked the speedo to read close to the same as my old one (with in a few hundred kms)
4DBBE1B6-6F3B-41BE-9216-279D203E4DE9.thumb.jpeg.d5e0bd324adef4e0523244e476882a7b.jpegfinished product ready to go back in
1A13C09B-3E44-45A3-8FE6-04D07DAE0104.thumb.jpeg.caecf7accfa454169a1a6b2ee66b5f26.jpegput it back in the car and took it for a test to check everything was working and parked it back in it’s house ?
  • Like 2
  • 1 month later...
Handy home workbenches hey. Noticed you have the one with draws and o'head cupboards in one of your FS topics. The other bench cost me $130 and rated at 500kgs. Bought mine at Bunnings for a good price.
  • Like 1
  • 3 weeks later...
Spent quite a bit of time over the last couple of days doing the fuel lines from front to back, it starts as a -8 from the tank and runs to the engine bay into the fuel filter, where it then splits into twin -6 and heads up to either end of the fuel railIMG_5076.thumb.JPG.3bdd561cb1ed8aa0eefd57cd3bb52a50.JPGIMG_5075.thumb.JPG.3ae8b07fc79e8e2ddffa83ce3ecff0ec.JPGthen comes out of the center of the rail to the pressure regulator IMG_5023.thumb.JPG.df50bdff7b0cdc10a6653532474b10ce.JPGI used the port where the pcv use to be for the vacuum signal and the original port for the pressure reg now only does the the map sensor
I was thinking of doing the same thing with the pcv. Do you remember the thread size for the pcv location?
the Thread in the manifold is actually 1/4 bsp but most of the fitting manufacturers don’t make them so I used a 1/4 npt. It still seals with no issues but only goes in a couple of threads due to the different taper
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
