I stripped the subframe down bare
1C1C4A1C-CDCA-455A-A030-52E42CE32983.thumb.jpeg.11163161404eebd9cf92d9bc29f85147.jpegGave it an inspection and noticed a few thingsFC95CC48-0A49-4EE6-88CA-E5E41BA0A697.thumb.jpeg.343d936ccf4f66003043c5ebbb681037.jpegECE768F0-7955-4313-A7C9-31F26AE9E699.thumb.jpeg.bf4d77925dce319e3bba5cbc8514ef52.jpegand basically the bushes are stuffed and rather then just do the ones that are gone I will replace every bush in the rear end
Thanks mate
Something else I should mention to make the a little more challenging for myself, I want it all back together and wheel aligned for roll racing on the 13th of April and I’m away for the last week of March and won’t be getting anything done that week
Last time I was out there I got to the second round of elimination but because the ratios in the 5spd are so bad my starting speed was to low and they were a car to a car and a half in front of me before the start line.
I’m hoping the 6spd it will fix that problem and will make me a lot more competitive
  • Like 1
20 hours ago, Anonymouse said:
Use the Motul/Nismo trans fluid
The change in ratios will fix the issue
I notice the nismo kit comes with gearoil but I always thought the getrag used atf?
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
