Anyone in Sydney that wants to do there’s to save buying the socket to do it, I’m happy to lend you mine if you leave a $50 deposit which will be returned to you when you return the socket
  • Like 1
  • Thanks 1
9 hours ago, r32-25t said:
Keeps the pressure in the pump, easiest way to know if yours is stuffed is while car car is sitting there idling you’ll hear the attessa pump cycle every couple of minutes.
Pretty certain my attessa pump primes every 10 seconds lol
I'm keen to know how did you find the change in ratio's especially for driving on the street in comparison to the 5spd box?
Does it make more sense re ratio's of 6spd v 5spd? and  the 4.11 rear diff.
Doing the same conversion and getting a tad excited, cant wait so trying to glean what you think.
I actually think it’s easier to drive especially taking off, I find 4th at 60km sits just under 3,000rpm which gives it a nice amount of torque when you come to a hill, get to about 70-80 and I put it in 5th and it just cruises along nicely
It’s great with the 4.11s, honestly if you have any reserves about it, don’t worry about them cause you won’t regret it
  • Thanks 1
Thanks - watched it several times listening to the changes. I absolutely love the sound the RB's make under load and the BOV's.
I'm really chuffed to hear you say it's easier/nicer. I cant wait.
Edited by Sinista32
In that race I was against an r32 Gtr with a big single and more power then me and he finished with his front bar lined up with my rear cause mine gets out of the hole so much better
  • Like 1
  • Haha 1
  • 4 months later...
Nothing “broke” but the ats twin plate while being a fantastic clutch was not strong enough for the mighty twins and slips when I run anything above my lowest boost setting
The clutch to replace it will be an os r3c that I picked up a couple of months ago from a member on here with very little use on it
after ripping the box out I sat the 2 clutches side by side and I realized this wasn’t going to work without some parts sourcing
After installing an r3c recently in my Gtr
make sure u use the correct length bearing carrier as the clutch is “thinner” and needs a long bearing carrier
mine was around 27mm long if I recall where as most other clutches require a 14ish mm carrier
  • Like 1
I did a heap of measuring and had worked out that was what was required and late today I picked this puppy up and it will fix my issue
I will be able to fit it all when I get a free second and take it for a drive again
Honestly I have no idea, Kyle from hi octane had it sitting around because their supplier had sent them the wrong part for another customer and he sold it to me.
i will check it for a part number tomorrow
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
