 The way I looked it. with the deck cracking being so common I didn’t want to chance it happening again and to be honest by the time you buy a block, test it, do the billet main caps, machine it, buy the head and main studs and etc you really aren’t getting much change from buying a billet block  and if it happened again then I’d really be behind
  • Like 1
Just now, BK said:
Jesus Christ Brett... Sequentials, Nitto strokers and now a Billet block ! You win Powerball or something ? 😉
I wish we (me and the mrs) just look at it as we will take the financial hit now to save it costing more in the future.
  • Haha 1
I can't talk either. At least that's good if your Mrs is helping - mine tells me to fk off and spend your own money !
We're ending up in very similar places with the TH1 32s with the Elite 2500, 6466, Nitto 2.8 stroker but I've went H dog and you sequential.
To be totally honest if I cracked another block I'd probably do exactly the same with the Billet block myself, so I'm interested on how it works out.
  • Like 2
4 minutes ago, Dose Pipe Sutututu said:
nice steal cap thongs Brett lol..
and congrats on the new baby (block) :D
We have a very good oh&s policy in our garage, if you hurt yourself I’ll push you in front of a bus and they can deal with it
  • Haha 2
1 hour ago, r32-25t said:
Also pulled the dash out to remove the heater core and ac core out DE9B0EEE-BB2D-43C9-87C7-FFD7870CDC52.thumb.jpeg.349837306c75c99caec7090d7720825d.jpeg
With what you have removed from the dash, can you get to the firewall mat? I have removed the vinyl dash, centre console etc. but it looks like you have removed a lot more.
I want to replace the firewall mat but a bit unsure about how big a job it is and whether I need to outsource it.
Cheers
Cheers
I just had another look and you would need to strip it even further then I have, the steering column, all the wiring, the metal bar and even the carpet needs to be pealed back as well. Basically you need to remove everything cause of the way it wraps around it all.
I thought I replied to this before and just realized that wasn’t the case
With us all our money goes into one account and I wouldn’t spend that kind of money without talking to her about it first
should be good to see what kind of difference the sequential makes, My goal is to run a 9 on drag radials (even a 9.99 would make me happy)
I’m looking forward to it all coming together and from what I’ve been told it’s not the major inconvenience everyone originally made it out to be.
One thing I did find out after paying for it is you have to use an external oil pump which wasn’t expected
  • Like 1
Same - want a 9 at over 140mph with the H pattern at 2021 Red centre nats so they can kick me out for not having a 'chute. Ideally I'd like it to be done without drag radials but they do make a big difference, as I was doing 10.5 - 10.7 passes between only 127 - 129 mph with the Trust 6 speed and ET streets before the 6466 went on.
So what are you doing with the oil pump setup ? Mechanical crank driven pump ? Wet or Dry sump ?
so that's another 20k on the tab for dry sump? :P
Billet not so cheap after all, but even cast needs dry sump!!!
Gtr fest is my goal cause it’ll be a fully prepared track
It’s going to have to be one of those 2 I’ll cross that bridge when I get to it, it’s a decision I can leave until just before the engine goes back in
  • Like 1
If you’re paying 20k for a dry sump set up your getting your ass raped
  • Haha 1
Thanks for taking a look, I appreciate it. Sounds like I might have my work cut out for me.
  • 4 weeks later...
  • 1 month later...
Car still hasn't moved, I’ve been told 2 weeks (feels like I’ve said that before)
been buying a few odds and ends 2565B423-BC3E-4FCA-AE4E-080CF943CD72.thumb.jpeg.472d4c66a749cc298586bccc325f6ce5.jpegsome titanium exhaust studs, a new rubber seal for the cam angle sensor and a new coil cover emblem
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
