It’s back on ground
and has power again
have started the wiring, first off by running the exhaust temp sensors into the cabin and plugged into their box
  • Like 2
22 hours ago, r32-25t said:
Yes we’ve gone through all that, I didn’t expect The twins to die every 6 months
How long do you think you'll get from a single? 1.5months as it's doing two turbos work, or 12 months instead :P
HAvent read entire thread, was it the actual turbo's you've had that keep failing?
  • Haha 1
The rear turbo died and then I fitted the single and the block died instead
  • Haha 1
slipped the main harness in and put the wires into their groups (injectors, coils etc)
ran the wires where they need to go and cut them to length
then fitted the terminals and labeled some of the plugs to prevent mixing them up
slipped the harness back to where it all goes, still waiting on a couple of connectors that I forgot to order
  • Like 2
1 hour ago, Shoota_77 said:
Must be starting to feel like it's getting close!
It actually does, I think the only thing that will decide if I make the deadline is getting the radiator
They're like a dime a dozen at JustJap aren't they? 😛
