3 hours ago, r32-25t said:
Ok so the reason I decided to cancel all Japan day is I was finishing off the last of the wiring and started to look at having to do the relays and fuses for the fuel pumps, thermo fans, trigger for the power steering pump and etc. after looking at the number of wires that were going into the car, I took a step back and thought nah f**k this there’s a better and much neater way to do this!!
insert pd16 (pdm) here and the problem is solved only issue is I now need to strip the wiring harness, remove the i/o 12 box from it and fit the pd16 instead
I got very lucky and it just happened they came into stock the day after I ordered it, now while this is a set back and will mean having to redo some work, it’ll end up being better for it
Surprised you didn't go the whole hog on the high-end nexus that's ECU and PDM in one! 😛
jealous of that PDM, I'm a poor man playing in a well funded man's sport... I'm stuck with relays and fuses ha ha ha!
I looked at it and worked out I’d either need to buy a nexus plus a pdm due to the the fact the nexus uses 3 of the 25amp out puts or just the pdm if I kept the elite in there
  • Like 1
No matter how many IO you have, you never have enough... Ha ha ha
The only other things I’d want would be more DPI/SPI to measure the 4 wheel speeds and do traction control. not sure my car will make enough power for it to be a real issue though
You're better off doing a GPS speed sensor vs. the wheel speed as your car would bake all 4x wheels, if the surface isn't optimum.
Having front and rear speed sensors and doing a traction strategy on that only works on FWD or RWD cars.
From someone in the GPS industry, you'd want it to be a good GPS module, with an actual accurate output (basically doing a lot of sensor fusion with gyros, compass, and accelerometers) or the TCS won't be that great.
For Brett's car the traction strategy would be for straight line attacks, so the Haltech GPS sensor would be sufficient for traction control in his application.
Fair enough, I can't see it being any where near good enough to compare GPS to wheel speed in most use. Imagine you drove under a tree in a corner, I'm sure we've all had that experience where we were apparently doing 60, then 120, then 30 in the space of a second.
I think with most all wheels drive cars you use both the wheels speeds and the gps, I agree the gps will end up useless in some situations and would be interesting to see how the system would react at those times
Most GPS modules are getting better than that, but still not great unless you're spending big big big dollars.
Biggest problem, is it relies on measuring distance, with decente enough error to make it quite difficult to detect did I really move, or just GPS error?
Which means you can have the GPS thinking you've moved when you haven't, and at the same time you've gone to launch and broken into mass wheel spin.
This is where you need a heap of sensor fusion from everything else.
GNSS and Vehicle Telematics is my niche professional area of work.
You would likely have more reliable wheel spin detection on an AWD using steering angle, TPS, and comparing the individual wheel speeds, as well as rate of acceleration, and comparing that with acceptable rate of acceleration at given speeds for given gears, and more so anticipating if it is wheelspin or not, vs using a GNSS sensor compared with wheelspeeds.
21 hours ago, TurboTapin said:
I was under the impression that Haltech does not allow the use of their GPS speed for traction control. It must be wheel speed sensors.
It definitely can, it just comes up as a speed sensor.
I just gave it a try and it's a no go without an addition wheel sensor. The error states "Traction Control for rear wheel drive requires at least one rear wheel sensor (Or drivetrain sensor) and at least one front wheel speed sensor."
You are correct!
I just played around with it myself and it shows the same error. A workaround is to just create your own Generic and apply ignition correct (as in take timing out) when there's a GPS Speed / Drive Train speed difference.
I'll end up trying this out one day as I want traction control.
    • Interesting. My tuner said after the tune that my fuel economy would be better but it is the exact same from what I could tell even though my car was running rich before lol. How much do km do you reckon you get on a full tank of petrol on your commute?
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
