3 minutes ago, Piggaz said:
It’s insurance for the engine and gearbox 🤷‍♂️
That what the haltech gauge and engine protection is for, let’s be real you have have the fanciest dash in the world but it’s not going to help at 8,500 when youre pulling the next gear.
  • Like 2
So what is the gauge on the A pillar going to tell you? Boost?
  • Like 1
meh, I've got the generic/link version in the stagea, and it is good to be able to see what is happening without a laptop all the time. Still a bit limited, but better than nothin
almost as good as a PowerFC controller from the 90s, without the tuning ability.
Let's be honest PowerFC hand controller is useless, no oil pressure, no oil temp, no AFR, no exhaust pressure, etc.
Shows water temp, battery voltage, AFM voltage, etc. Lol.
The main thing I want it to tell me is the oil temperature, I’ve got few pages in it to see other things as well
  • Like 2
I decided to replace all the door trims and rubbers here’s a few comparisons of new vs old
IMG_9667.thumb.jpeg.0ed1edb25e1d890698721eee3c32cbd2.jpegIMG_9668.thumb.jpeg.9a4306457eb90751cf440be7698e9dad.jpegIMG_9669.thumb.jpeg.3ad02c397b2d78a71c34b6f25c931774.jpeg
and all of the old bit in a pile
Sometimes you don’t realize how stuffed parts really are until you replace them
  • Like 9
10 hours ago, MBS206 said:
Where did you buy all the rubbers for around the doors etc?
You'll struggle to find them for the R33 shit box.
I bought the last RHS one from them, after only being able to get the LHS off Amayama.
Those pesky Muuurricannnsss have cleaned up the spares.
wiring is finished
At the same time the bay got painted I got the purple set of covers stripped and then painted in r33 midnight purple, the photo doesn’t really do it justice
IMG_9697.thumb.jpeg.2ba747ab5feb1b330e38b1f00db4009e.jpegIMG_9698.thumb.jpeg.f908213bb81c865550a3b9e25af9e8d7.jpeg
I didn’t like all one colour look and took the pant off the letters with some wet and dry. Also you can spy the GTRs new home in the background
  • Like 3
3 hours ago, Old man 32 GTR said:
Car is looking mint, at this rate you’ll be finished way before me, so you’ll have to take me for a run in it, I can’t remember what a working GTR is like? Lol
I was hoping to have it ready for the Bathurst cruise but I think just that went out the window. I’ll do a bit if an update when I can
Wait, there are people that own GT-R's that work?  Not a concept i was aware of.....  :)
  • Haha 2
One old and one new cover just to see the difference
More brand new timing cover bolts
and all the covers on just to see how it looks complete
i didn’t get photos but after this I fitted the radiator hoses and cooler pipe and then preceded to fill it with coolant
guess I have an issue 😡
  • Sad 2
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
