7 hours ago, robbo_rb180 said:
What ended up being the issue?
New shed? How big ?
Something to do with one of the sleeves, haven’t been told exactly what yet, hopefully will find out when I pick it up and get the chance to talk to the them face to face
yeah new shed, it’s only a 6x6.5 but for a suburban area is a pretty decent size
  • 1 month later...
On 12/17/2023 at 10:22 AM, Duncan said:
Yeah 6x6.5 is pretty decent workspace as long as there is only 1 car in it, it's so nice to have space to work
I have come to find my 9x6.5 isn't big enough...
Too many toys (tools)... I think it's time to wall in the car port bay and move some stuff... Hmm...
Brett, update?
How's garage build?
Engine rebuild?
Isn’t really much to update,
the shed I’ve been trying to get the slab down but the certifier keep finding hoops for me to jump through, I’m hoping I’m somewhere near close now.
the car I haven’t seen since November, the engine isn’t back yet and either is the sump. I’ve already written off gtr fest and am starting to doubt I’ll make any other event this year
  • Sad 1
Ok it amazing how much things can change in the space of 2 days.
the shed is at the point where all I need to do is organize the concreter to do his thing and it’s off and running
with the engine
  • Like 3
with the engine
Awesome!
So.....  Have they given you the FULL story as to what it was?  Warped sleeve, cocked sleeve, cracked, driver error 🤪...??
1 hour ago, Shoota_77 said:
Awesome!
All I could get was it was leaking and they resealed it.
39 minutes ago, admS15 said:
Is it back in yet? Chop chop😉
I don’t have the car or the sump, my aim is to get my shed built and then get the car in there and start working on it again
  • Like 1
  • 3 weeks later...
  • 4 weeks later...
I decided to rebuild the throttle bodies because they didn’t feel smooth when you opened and closed them
them when I started
IMG_0269.thumb.jpeg.bc2200a5de997acc2e2cacda6bf30448.jpegIMG_0270.thumb.jpeg.6e96a8c64b75353ff9be9f6b261d18a3.jpeg
bit of heat to break the seal on the screws
press out the shaft
new bearings next to the old ones
IMG_0273.thumb.jpeg.605a6f300310d401592df60f57c8249d.jpegIMG_0274.thumb.jpeg.9215a330804ac81ae03e69777d0b3eb7.jpeg
cleaning the old throttle coat off the housing and butterfly’s
all clean
IMG_0276.thumb.jpeg.e4fe50ef0e6536ad04a13dba039ae5c2.jpegIMG_0277.thumb.jpeg.f98ab995dcb1e185cd654ea8ea3ce66e.jpeg
new bearing and the bearing locks which also hold the seals in place
IMG_0278.thumb.jpeg.e39f6bd8fcb89da12dec0e890cad892c.jpegIMG_0279.thumb.jpeg.3fe3a226c50f0081053ded9dd7251577.jpeg
new throttle coat applied and the new seals that I pressed in
once it was all done the throttle felt a lot smoother to open and close and definitely a much better piece of mind
  • Like 6
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
