The sensor grounds all go back to the ecu and none of them are on the battery ground, Adam suggest putting the flex sensor straight to earth because of it being a frequency signal can play with the others
it does it on the road now that I’ve driven it and paid attention, not sure if it’s rpm or load making it happen though
One of the issues Adam mentioned was the tail shaft center bearing being flogged out, I took the shaft down to be rebuilt after a conversation with the owner of the shop it was decided a whole new shaft was the best way to go.
so after taking measurements and waiting a week my new shaft was ready to pick up
 IMG_1502.thumb.jpeg.9a059e71280a53246a59242b861b9e29.jpegIMG_1505.thumb.jpeg.20458f2f09668823c93cddfc2f7c6efe.jpegIMG_1503.thumb.jpeg.6c2c3a3ac64e22ea38374761253227d9.jpeg
new and old shafts next to each other, yes the new one piece shaft and was worried about vibration, after driving the car turns out that there is nothing to worry about
The only requirements/issue with one piece tail shafts is tail shaft RPM, the length of it, the diameter of it,  the pinion angle, and material used
Daily driving at 110 kph it top gear with a one piece will probably never see any harmonic issues at ???? tail shaft RPM, but, at 200kph you might see some harmonic issues if your tail shaft isn't spec'd right
I looked into this alot when I was looking at a new tail shaft for my VX SS after it constantly flogged out centre bearings and getting vibration over 160kph, in saying this my "pinion" angle from the gearbox to the centre bearing was the issue, slightly to much angle caused the centre bearing to flog out from harmonic vibration at high tail shaft RPM, but for me the issue was the 12mm lower engine mounts, after getting the angle of the dangle from the transmission to the centre bearing lined up correctly, and to within spec (OEM height poly mounts), the car is happy at 200 kph (125mph at the drags) now even with the OEM spec centre bearing and rebuilt OEM 2 piece tail shaft
What's your tail shaft specs?
  • Like 2
Approx 1m long, chrome moly, hardy splicer unis. Didn’t measure the diameter. The shop that built it also builds the shafts for b2r, jem, maatouks, etc and built the shaft to the same specs as their cars that’s are running 7 and 8 second passes!! Which say to me that it can handle some big mph
  • Like 1
It also depends on gearbox ratio.
Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm....
....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc.
That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
  • Haha 1
2 hours ago, Kinkstaah said:
You may never get into those scenarios, like most ruined GTR's from Western Sydney don't 😛
they might see those prop shaft speeds for 1 to 2 secs only
With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out....
I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
Shaft speed would be the same, however it's how long they hold it there for and repeated conditions.
FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
7 hours ago, GTSBoy said:
And over it. Need to stop it coming through the floor.
From videos and photos of them coming apart, I'd be adding a loop near the front of the shaft too.
Have seen the remains where it has let go, been caught by the centre loop, but shaft is happy to bend about 90degrees at that point and proceed to slap the shit out of everything as it dies a catastrophic death.
Just now, GTSBoy said:
It's a race to the death between the oil pressure and the fuel pressure (from the tailshaft spreading the fuel line out across the underside of the car).
I am actually chuckling about that out loud!
Sorry, I confused myself here. I meant it would hit critical RPM at the kind of speeds where engaging 5th in most skylines is a possibility. Rear diff ratio matters tho.
But yeah if people are trapping 150mph+ then... their driveline is likely already tinkered with...
I just feel a tailshaft pole vault is not something anyone wants to run the risk of/test when they know the numbers. It may be entirely fine and overblown as a risk...
2 hours ago, Dose Pipe Sutututu said:
Brutal cnuts 😂
Brett's car has a dry sump thing though
Dry sump? Is that like where you don't put oil in, and leave the car parked in the garage because it's worth so much now and is like a beautiful museum piece? 😛
  • Haha 1
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
