R32 Gtr Long Term Love, Now Project
The sensor grounds all go back to the ecu and none of them are on the battery ground, Adam suggest putting the flex sensor straight to earth because of it being a frequency signal can play with the others
it does it on the road now that I’ve driven it and paid attention, not sure if it’s rpm or load making it happen though
One of the issues Adam mentioned was the tail shaft center bearing being flogged out, I took the shaft down to be rebuilt after a conversation with the owner of the shop it was decided a whole new shaft was the best way to go.
so after taking measurements and waiting a week my new shaft was ready to pick up
 IMG_1502.thumb.jpeg.9a059e71280a53246a59242b861b9e29.jpegIMG_1505.thumb.jpeg.20458f2f09668823c93cddfc2f7c6efe.jpegIMG_1503.thumb.jpeg.6c2c3a3ac64e22ea38374761253227d9.jpeg
new and old shafts next to each other, yes the new one piece shaft and was worried about vibration, after driving the car turns out that there is nothing to worry about
The only requirements/issue with one piece tail shafts is tail shaft RPM, the length of it, the diameter of it,  the pinion angle, and material used
Daily driving at 110 kph it top gear with a one piece will probably never see any harmonic issues at ???? tail shaft RPM, but, at 200kph you might see some harmonic issues if your tail shaft isn't spec'd right
I looked into this alot when I was looking at a new tail shaft for my VX SS after it constantly flogged out centre bearings and getting vibration over 160kph, in saying this my "pinion" angle from the gearbox to the centre bearing was the issue, slightly to much angle caused the centre bearing to flog out from harmonic vibration at high tail shaft RPM, but for me the issue was the 12mm lower engine mounts, after getting the angle of the dangle from the transmission to the centre bearing lined up correctly, and to within spec (OEM height poly mounts), the car is happy at 200 kph (125mph at the drags) now even with the OEM spec centre bearing and rebuilt OEM 2 piece tail shaft
What's your tail shaft specs?
  • Like 2
Approx 1m long, chrome moly, hardy splicer unis. Didn’t measure the diameter. The shop that built it also builds the shafts for b2r, jem, maatouks, etc and built the shaft to the same specs as their cars that’s are running 7 and 8 second passes!! Which say to me that it can handle some big mph
  • Like 1
It also depends on gearbox ratio.
Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm....
....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc.
That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
  • Haha 1
With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out....
I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
Shaft speed would be the same, however it's how long they hold it there for and repeated conditions.
FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
7 hours ago, GTSBoy said:
And over it. Need to stop it coming through the floor.
From videos and photos of them coming apart, I'd be adding a loop near the front of the shaft too.
Have seen the remains where it has let go, been caught by the centre loop, but shaft is happy to bend about 90degrees at that point and proceed to slap the shit out of everything as it dies a catastrophic death.
5 hours ago, Dose Pipe Sutututu said:
but for how long? would it handle a few laps around SMSP in anger?
Its an RB26.
It won't have oil pressure that long... 😛
  • Haha 1
It's a race to the death between the oil pressure and the fuel pressure (from the tailshaft spreading the fuel line out across the underside of the car).
  • Haha 2
I am actually chuckling about that out loud!
Sorry, I confused myself here. I meant it would hit critical RPM at the kind of speeds where engaging 5th in most skylines is a possibility. Rear diff ratio matters tho.
But yeah if people are trapping 150mph+ then... their driveline is likely already tinkered with...
I just feel a tailshaft pole vault is not something anyone wants to run the risk of/test when they know the numbers. It may be entirely fine and overblown as a risk...
2 hours ago, Dose Pipe Sutututu said:
Brutal cnuts 😂
Brett's car has a dry sump thing though
Dry sump? Is that like where you don't put oil in, and leave the car parked in the garage because it's worth so much now and is like a beautiful museum piece? 😛
  • Haha 1
    • No I’m just reading shaking my head
    • Yeah, after my first post i did notice that my tps wasn't calibrated exactly to the tee. So I did calibrate it: applied the settings, rebooted ecu and it's still the same.
    • Lololololol... Poor bastard will read all this and have a sads.
    • Dry sump? Is that like where you don't put oil in, and leave the car parked in the garage because it's worth so much now and is like a beautiful museum piece? 😛
    • Nissan Fuga Y50 2009 VQ35HR 313 hp / 230 kW RWD Also sold as Infiniti M overseas. Performance sedan built on the same chassis as Skyline V36 or Infiniti FX. Great colour with a fantastic velour interior. Very quiet and fast car (<6s 0-100), but can also be very economical for performance (long-term average consumption 11/100 km) I imported it five years ago, and it was well looked after. It has a full service history and a balance of ACT rego. There are no finance or PPSR issues with the car. Has all the features you'd expect from a luxury car. ABS brakes Stability control Traction control Dual-zone climate control Power and memory front seats and steering column Power passenger ottoman Smart key access Push button start 2 parking cameras Steering wheel audio controls Adaptive radar cruise control AFS aiming headlights Xenon HID headlights Security system Original Nissan remote start system Two original keys Dual-channel dashcam Blackvue 750 with PowerMagicPro for battery-aware parking recording Regularly serviced with a lot of major items done: Full new original Nissan suspension shocks throughout Performance CSF radiator Recent tyres, less than 10k on them New drive belt New bonnet struts Brakes recently done The car comes with a fully converted AV system with Australian GPS maps, DVD, and radio ($2k job). I really love this car, but I have too many cars and too many Nissans in the family, so unfortunately, I need to sell it. Priced at $18500 The car can be seen in Curtin. Thank you for your attention.
