2 hours ago, admS15 said:
Which is why 8374 makes sense. Isn't that right Grant??
Na, twin EFR's is better.
Cos it's one more than one hey Bill?
  • Like 1
2 hours ago, r32-25t said:
That kit is far to untidy,
Wrap the bonnet with a photo of stock engine bay, that way you'll look at it and say "that's tidy engine bay" :P
Sent the rocker cover out to craved coatings and got it done to match the rest of them IMG_4744.thumb.JPG.6afa6134301a3d4fee17e346f645c60a.JPGam going to uncover the writing on it due to the candy looking different there compared to the rest
  • Like 1
Did some work on it over the weekend, fist pulled the timing belt off and inlet cam cover off
and new cam in for clearence measuringIMG_4811.thumb.JPG.d6fef983e41a59b5e176ea8d2d79bc1e.JPG
6 of the clearances are out of spec and the shims have been ordered and should hopefully be here in the next couple of days
  • Like 1
Parts are back from ceramic coating IMG_4822.thumb.JPG.5cf3f8ee475476153faf90d50043a1e0.JPGi also bought plugs for the original oxygen sensors because I no longer use them and they will just be in the way when installing the turbos
  • Like 3
Had a couple of hours over the weekend to work on itIMG_4827.thumb.JPG.3af7f04e2cb1aed102f7d208a5971def.JPGthe shims had arrived a few days before an i fitted them, checked the clearances were spot on
IMG_4828.thumb.JPG.3db9bfcd9c9a8326e7ccd08c1287e64e.JPGthen moved onto the cam gears and timing belt
  • Like 3
I then grabbed a die grander with basically a scotch bright pad on it and attacked the powder coatIMG_4833.thumb.JPG.7f2c88345b2389c350619f4fe737f249.JPG halfway done
IMG_4834.thumb.JPG.2353981157b2bd15f90050fd90bca345.JPGpowder coat gone and then I ran another pad over it to give it a machined look
IMG_4835.thumb.JPG.7c791d0e52471563868b131866efcdd9.JPGand the finished product
  • Like 1
Then got to fitting it to the engine IMG_4836.thumb.JPG.04867ea540bf3c0762a2b3f6934ce1f5.JPGhere it is fitted to the engine
IMG_4837.thumb.JPG.df0c7aade7b3e1f6dac59e3e349b01ce.JPGthis comes with the kit and of corse is the reason the kits costs so much lol
IMG_4838.thumb.JPG.a9df0418147d17669701275a29de6702.JPGand with all the sensors and oil cap fitted,
Had some time today so I decided to spend it playing with the car IMG_4822.thumb.JPG.d009be87cb63945f4e5725c08b67dc90.JPGIMG_4844.thumb.JPG.5f6d12c7e23b38252856bef4d6e73724.JPGfinally unwrapped all the parts I got ceramic coated, it's a shame you won't see them once they're installed
And finally the turbos can start going on, some people will be a bit disappointed IMG_4824.thumb.JPG.28e6ae604b5f998129b74c4849a2e97a.JPGIMG_4823.thumb.JPG.f5c51bbaee14e0635d24ed4146f4b0bc.JPGbut I'm staying twins (that was never a secret) and they are nothing specialIMG_4825.thumb.JPG.b6560843efd7188c06aba5905a80ef37.JPGjust a basic set of -5s with very low kms that I got for a price way to good to pass up
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
