I also decided to get rid of the airflow meters,IMG_4845.thumb.JPG.f7bbe6cb9cbc2261a8255d24b1c5d712.JPGno because I think they're a restriction but just cause I could
IMG_4846.thumb.JPG.1e093777a4a734022cd5785adf6dfdc7.JPGso I got the hks adapters IMG_4847.thumb.JPG.53b42138ac9cf4e6698abee7fa738366.JPGand here they are in the car, I forgot to take a photo out of the car
  • Like 1
Reason for the front bar coming off was fitting a new intercoolerIMG_4851.thumb.JPG.5e2b87f00f2766f404453245e396917c.JPGIMG_4852.thumb.JPG.1b12420b549c1f4fb39ddcf5e9ba2379.JPGwhich is a plazmaman pro series with the 76mm core because I didn't want to modify the front bar to fit it
IMG_4853.thumb.JPG.0c7ffc752833ea9a584f5276e17d954d.JPGquick photo of new and old next to each other, i didn't realize how much bigger it was till I did this
  • Like 1
So for what I thought was a bolt in intercooler took a lot longer to actually get on the car, the quality and mounting points were perfect but due to the extra width I had to undo the bumper support and move it out of the way and slide it all in togetherIMG_4855.thumb.JPG.5891ad1100e5196f9901b598eed75053.JPGand how close it is to the front support with it all fitted againIMG_4854.thumb.JPG.45b088bd2527286c408b7a10663adb49.JPG
Speaking of getting the front bar on that was a nightmare, I knew the r32 had less room in the front but I didnt know it was this much less.
Because I wanted to keep the factory mesh in there i had to trial fit the front bar and bend the mesh and try again, this happened about 6 times to finally get it right but was worth the effort
IMG_4903.thumb.JPG.0b264da1000138f9fdaf3ead0520050f.JPGIt's stock sir I swear ;)
  • Like 2
Didn't update this last week cause all I did was the wire the vcam and flex sensor into the ecu, plug the wide band controller into the ecu and ran the wire to the boot to switch the second fuel pump
But this week I was a little more constructive IMG_4886.thumb.JPG.2c5678b60f910a407f156e7269beae42.JPGfirst took the discs off and sent them out to be machined
IMG_4897.thumb.JPG.611e9461c948db0ada023d1dced7782f.JPGback from machining and got some upgraded pads to fit as wellIMG_4929.thumb.JPG.50f9b0e38ee207f88488e73d79292d6a.JPGand all fitted
Also grabbed some braided lines and fitted them IMG_4928.thumb.JPG.94b5f5003117e9afba5dd85e1227cf71.JPGdidnt get a photo before I put them on but you can see it there
IMG_4930.thumb.JPG.fd47afb6e52b84d6f3c9722b3e5fd35f.JPGalso fitted a brand new r33 gtr master cylinder and replaced all the brake fluid,
turns out the plug for the fail light is different between 32 and 33 so will go to Nissan and see if they can supply a plug and pins set
Got a delivery the other day from Japan of corse IMG_4936.thumb.JPG.2d386248eb5641067cf762b2e968a35f.JPGIMG_4937.thumb.JPG.91ef7cc76a3d2dbc04dd8b2ca155f10b.JPGIMG_4938.thumb.JPG.aba4669831d8d3fce4d2dac7c9a9ba47.JPGand he first thing out of the box is an ard 150amp alternator, the original was only charging at 12.3v so with the extra load was only going to get worse
Didn't get photos of it installed before I refitted everything including the radiator and coolant then I rechecked the running voltage and I won't need to worry about it again IMG_4942.thumb.JPG.7644f2ef39153931576f416bb280f556.JPG
