Jez tried to start the tune on Friday and couldn't get the cam to move, lots of diagnostic work later we found the cam gear was jammed, a lot of problem solving we managed to work out what was causing it and got it working today (Tuesday).
The tune has started and it's looking promising
  • Like 4
The e85 tune was done today and the result is exactly as I had hoped, I won't give the final number till the car and dyno sheet are in my hand but I will say at 4500rpm it's already making 250kw ?
  • Like 2
Picked the car up today and all I can say is HOLY f**k. It's not even the number it makes it's how quickly it makes it. It has better response then my old -7 set up and just walks away. The only time the -7 set up matches it is when your foot is on the clutch stopped at idleIMG_2794.thumb.jpeg.588b67a26fde7d882ddf55e089c1f03d.jpeg
now for the future of this car, I'm done with chasing power!!! I'm over the moon with how it drives. So now I'll be just doing some general maintenance and improving things that may break. I will still be updating this thread as I go
  • Like 8
  • 3 weeks later...
when I had the car wheel aligned last time I was told those castor rods I had put in the car were rubbish and when I ordered the alternator I also ordered some Cusco carstor rods fitted them and had the car aligned again.
now I could have sworn I took a photo of them before and after installing them but I can't find the photos
  • 4 weeks later...
New one arrived a few days later 2B8DEF95-EBE1-49C7-A38F-9649790836D4.thumb.jpeg.48b78c0df3d72b49ab445516ef74c419.jpeg
and slipped it onto the gearstickFA2DBB39-881A-45F9-97DA-9E3B6323286B.thumb.jpeg.35703aa7925b0636e5f9b013e1e29e36.jpeg
dropped it into the box checked the fluid level and when I get around to it I’ll put the car back down give it a wash and take it for a drive
  • Like 1
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
