Anyone in Sydney that wants to do there’s to save buying the socket to do it, I’m happy to lend you mine if you leave a $50 deposit which will be returned to you when you return the socket
  • Like 1
  • Thanks 1
9 hours ago, r32-25t said:
Keeps the pressure in the pump, easiest way to know if yours is stuffed is while car car is sitting there idling you’ll hear the attessa pump cycle every couple of minutes.
Pretty certain my attessa pump primes every 10 seconds lol
I'm keen to know how did you find the change in ratio's especially for driving on the street in comparison to the 5spd box?
Does it make more sense re ratio's of 6spd v 5spd? and  the 4.11 rear diff.
Doing the same conversion and getting a tad excited, cant wait so trying to glean what you think.
I actually think it’s easier to drive especially taking off, I find 4th at 60km sits just under 3,000rpm which gives it a nice amount of torque when you come to a hill, get to about 70-80 and I put it in 5th and it just cruises along nicely
It’s great with the 4.11s, honestly if you have any reserves about it, don’t worry about them cause you won’t regret it
  • Thanks 1
Thanks - watched it several times listening to the changes. I absolutely love the sound the RB's make under load and the BOV's.
I'm really chuffed to hear you say it's easier/nicer. I cant wait.
Edited by Sinista32
In that race I was against an r32 Gtr with a big single and more power then me and he finished with his front bar lined up with my rear cause mine gets out of the hole so much better
  • Like 1
  • Haha 1
  • 4 months later...
Nothing “broke” but the ats twin plate while being a fantastic clutch was not strong enough for the mighty twins and slips when I run anything above my lowest boost setting
The clutch to replace it will be an os r3c that I picked up a couple of months ago from a member on here with very little use on it
after ripping the box out I sat the 2 clutches side by side and I realized this wasn’t going to work without some parts sourcing
After installing an r3c recently in my Gtr
make sure u use the correct length bearing carrier as the clutch is “thinner” and needs a long bearing carrier
mine was around 27mm long if I recall where as most other clutches require a 14ish mm carrier
  • Like 1
I did a heap of measuring and had worked out that was what was required and late today I picked this puppy up and it will fix my issue
I will be able to fit it all when I get a free second and take it for a drive again
Honestly I have no idea, Kyle from hi octane had it sitting around because their supplier had sent them the wrong part for another customer and he sold it to me.
i will check it for a part number tomorrow
    • Welp, too late already committed to the cam cover breathers to be welded on. I did think about adding a catch can in line with the drivers side sump breather as a phase 2 along with a drain to the sump on the original catch can but with an inline ball valve so I can have it closed if needed.    Likely a single breather would have been enough but I think I’m overcompensating to hopefully not have to empty my catch can and clean up oil over flow every session.    out of curiosity has anyone actually measured crank case pressure before and after various mods? I’m considering adding a sensor for science
    • Is it a dog or synchro box? I guess either way, if it is new and crunching in one gear only, it has to come out and go back to the shop to check/measure as there is either an assembly or manufacturing issue
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
