The intake pipe was made up and the blow off valve pipe modified so they will recirculate.
also took the blow of valves out of the car 7EEDBB46-9E19-4D65-BE83-313A2B673C65.thumb.jpeg.278024be8ad2cd7dc115f6f7a8310bcc.jpegand swapped over to a set of bolt on gfb ones 44C33312-2AD2-404B-8120-B20B9981B137.thumb.jpeg.b9165f3b4e7c5ee1fa8396b0777d8731.jpegand then put all the bracket and etc back on so they’re ready to fit back in the car 9A30F535-04FB-4071-BE91-7F0BB3B26888.thumb.jpeg.74220a455b9309a241fb94a6b6a15e63.jpeg
  • Like 1
Could have saved money and not run any BOVs, more money for bags and bitches lol.
Also dose is better than whoosh noises, and you're not running a BW, it's  it going to explode with the wrong shaft RPM or a bit of pressure against the compressor when the throttle is shut ?
Also Dose Pipe Sutututu: (note, this is not a BW)
On 17/12/2016 at 5:43 PM, Dose Pipe Sutututu said:
yyyeaahhh mmaateee kakafuarkingdu..
Overspeeding and compressor surge at high wheel speeds are both things known to break turbos since god knows when - they are why blow off valves exist, and why compressor maps are done with a cut off point which is earlier than where the flow completely chokes.   These phenomenon have been recommended to avoid since they have been breaking turbos since WAY before EFRs existed, and have broken pleeeenty of non-EFRs since well after they were released.
Telling people that it is only an issue for EFRs is pretty bullshit advice for people you are giving it to, and also a pretty major exaggeration of the fragility of EFRs.
Calm down @Lithium you clearly don't get a joke, also that turbine snapped because my motor exploded and put chunks of metal through the motor, not because it was oversped.
It was a joke, same way you and your buddies tell the world Precision turbos are junk and you need 15 oil filters.
  • Like 1
There wasn't anything put in there to make it seem like a joke otherwise I would had just lolled.   No worries about my level of calm, I just don't like seeing bad advice being left unquestioned... if it wasn't clear to me as a joke then it may not be to others so had to make it clear that it's very wrong - joke or otherwise.
I have no idea what that last line is about, but you appear to be confusing me with someone else.  I have opinions and friends have opinions, they sometimes overlap and sometimes they don't - whatever you are talking about there is nothing to do with me.
Edited by Lithium
Nah I don’t really want dose, always like the way the gtr valves sounded
Picked this up 376983A4-FCDE-4442-83BE-77FC3C7D216C.thumb.jpeg.8ed40213c04622b9d7acd144ca9b456b.jpegit the electric power steering pump out of an astra
and after modifying the bracket to it’ll sit flat I worked out I’m going to sit it about here D0E84407-405D-4B2F-972A-17CBCE20316D.thumb.jpeg.ac6e832d1566dd2fdccbc84041ed7a73.jpeghaven’t mounted it yet just sat it there and went to the fitting shop
Does that one have a vehicle speed input? At least you won't throw PS belts anymore (if you ever did).
I kept spitting PS belts when the motor was spun close to 8.5k on the limiter at a skidpan. Had to pop it back on twice then ended up lowering thr rev limiter (no fun in that).
No it’s just stays on and I’ll use the factory solenoid on the rack to change the power assistance.
i never had belt throwing issues, it’s just for room and trying to tidy up the bay a little
Fuark. When I was doing mine I was wondering if I should do it like this or black. I bitched out and went black.
Hurry up and get this fitted so I can hate you even more haha
#sexspec
Edited by WantGTR
  • Like 1
  • Haha 1
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
