Surge tank arrived a couple of days ago and after some assembly and a lot of speed flow fittings it currently looks like thisA6BF4BA7-D7CD-45F2-97F3-ADF539903236.thumb.jpeg.086daddf8d2e69fc1a5a9b8aad9b6d73.jpegnow just waiting for the fuel pumps to arrive and I’ll fit and wire them inside then fit the tank into the car
  • Like 2
20 minutes ago, BakemonoRicer said:
I also like how everyone is getting big fuel system after everyone told me they’re not needed haha
Yeap, my fuel system needed the Ford green top 42lb- 440cc injectors to get it up near 360-400kw
The stock 28lb - 300cc only got me 260kw at around 90%
Dommegabudget
It’s a 4L which is plenty and the pumps are the same size as previously, the only reason I’ve gone this way is I wanted the original gauge sender back in the car
How do those fuel hats work with the factory fuel inspection cover, I assume it doesn't fit and you need to run surge tank/pumps in the boot, and then somehow seal the boot to cabin for vapour?
The system in my car is not megadonwhatever spec, I just run -6 lines from the standard hat with a lift pump in the standard cradle, to an external surge tank with external pump under the rear seat floor which means all fuel stays out of the cabin.
It will be mounted in the boot and because I’m using the ptfe (Teflon) hoses and the tank is hard anodized it doesn’t smell
I already have -8 hoses running from the front to where the frenchies hat in the factory tank was. now I’ve fitted the factory hat back in with -8 bulk heads and I’ll run lines from the hat to the surge tank and then hoses from the surge tank into the -8 lines already in the car
  • Like 1
You have 15k worth of fuel systems in 2 300kw cars. 🧐
They definitely weren't needed in your situation. 1x $280 525 Walbro in each car woulda been fine. Even NASA woulda approved!
  • Haha 6
should use a few 60s or 45s so they're not all bunched up :)
(feel free to ignore, and also ignore those fly back diodes, will be hidden in the wiring one day)
  • Like 1
Yeah I wasn't sure of the data underlying the recommendation, I run the factory hat with no issues with a little over 300kw and an external tank.
And thanks Brett, I was confused and thought your pic was a hat for the standard tank, I can see it is the top of a surge tank which makes much more sense.
That works for 33/34 owners at the hat in the fuel tank sits higher then the surge tank, r32 the hat sits lower then the surge and the lines come off the surge tank and then go straight down
Oh derp!
You are correct, R32 is setup similar to S13s, forgot that.. so yeah feel free to ignore lol
  • Haha 1
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
