Thats why its just easier to buy from Herman even if it is a bit more. At least that way you know its already tested and what it can handle.
Rd28 is a lot of f**king around but worth it if you weren't already down the 2.8 rabbit hole
  • Like 1
I enquired and basically got brushed off
Hmm I thought it was a service they offered. I just let Anthony from Dahtone sort that for me so can't say ive had to enquire directly.
I think they do, they told me there was a 2 month or so wait and when I said that was fine with me and I still want one, I never got a reply
  • Sad 1
I think they are just like that to deal with sometimes, probably a symptom of being far busier than they are equipped to handle. Ive spoken several times to Herman about developing a product with them and everytime I speak to him he is very interested and keen, but then in between it is very difficult to get a reply and I can go months without hearing anything back from inquiries.
No stress for me as I'm not in a rush to develop, but as a customer it sucks. Have been in that position as a business myself though, where you're really just too busy to take on a job but you are still interested so you don't want to say no so you don't reply while you try to think of a solution, then before you know it you've forgotten and its been 2 months since they contacted you.
  • Like 2
Small update, no photos but the head and all the parts have been dropped of to be ported and put together. The only parts that won’t be brand new is the head casting and cam caps
  • Like 2
1 hour ago, r32-25t said:
At the moment I still don’t have a block and am exploring options
If you're not looking at a new 05U block, what are you leaning towards ?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
