On 30/07/2021 at 5:42 PM, r32-25t said:
Bay got blasted today 7D44A096-0B5B-4B47-9DD1-BEC7ECD53BF2.thumb.jpeg.0a273f55f37bc2a048de99fb81ccec26.jpeg
gets etch primer tomorrow and then paint during the week
Nice!  Are you going to do any hole deleting or rough area smoothing or just lay the paint on as is?  Either way it will look stunning once it's done!
  • Like 1
They are going to replace any of the seam sealer that’s damaged and a couple of little thing and then leave the rest of it how it is and paint it the same as the outside
  • Like 1
On 16/07/2021 at 5:37 PM, r32-25t said:
all ported and the chambers opened up and all the good bits fitted and valve clearances set
Curious on why you removed the squish pad?
Squish pads produce;
  • A required (read as "desirable") amount of turbulence in the mix right at the end of the compression stroke. This greatly improves mixture distribution and mixing at the point where it is getting ignited, leading to obvious desirable improvement of pretty much all the combustion parameters of interest.
  • A reduction in the surface area of the head and piston facing the flame at and near the moment of ignition. The tiny little volume of mixture trapped in there is a better compromise than the otherwise exposed but narrow corners all the way around the rest of the combustion chamber where it meets the edge of the piston. Small combustion chamber volumes and decreased surface area should cause improved resistance to detonation, rather than the commonly held opinion as expressed by R32-25t above. Which is not to say that once the usage of the engine is pushed waaay beyond where the OEM engineers expected it to be, that perhaps the hot edges of the squish pads do trigger detonation.
I'd be willing to believe the improvements in ignition triggering, ECU accuracy/speed and fuels (ie E85) have probably exposed the old belief as being more of a band-aid for problems with real causes elsewhere.
  • Like 2
On 03/08/2021 at 11:52 AM, r32-25t said:
As Paul said can of worms but by removing the squish pad it allows you to run much higher compression ratios without detonation becoming uncontrollable
I know it's a touchy subject, however just really curious to hear other people's thoughts on this.
My thoughts + most of these cars are running E85
The main issue was that in the past people threw on thicker than OEM head gaskets to lower the comp, at the same time without really thinking about increasing the squish area/volume as a by product of the thicker head gasket. This would indeed cause those undesirable outcomes with pre-ignition and hot spots.
There are argument for and against removing them, everyone’s option will always be different. The cars I’ve seen with them removed seem to make more power which says they have better flow.
the engine is not going to be a low comp dog, it’s compression ratio is going to be well above the factory 8.5:1
  • Like 1
Not related to the squish pads. Different things.
If that's in reference to what Dose said about thicker head gaskets, then also missing the point.
'Twere me, I'd be looking to increase the amount of squish in a modern engine build. Not decrease it.
  • Like 2
https://en.wikipedia.org/wiki/Pent-roof_combustion_chamber
Faster burn time, by introducing turbulence at the top of the stroke thus improving combustion
Designed by the frogs
From my understanding most modern engines run them
Why do people remove them.....??????
because it "can" lead to heat spots forming and pre-ignition happening, however this generally due to running thicker head gaskets to lower the comp for big boost.
Very 1990s way of tuning, nothing wrong with it but with E85, ECU and injector tech these days you would think there's no need to lower comp.
Yeah, to me it seems that removing them is removing an engineered design for better combustion
Is it a proven thing that they are the real cause for "possible" detination when running 98
Or is it more a thing when running on the ragged edge of a good AFR?
To me, the sharper edges on valve reliefs would be more of a place to propagate hot spots and det???
  • Like 1
Calculate the chamber volume and have pistons made to suit the increase in chamber volume to hit the target comp ratio.
I took the intake squish pad out when I built my head 10 years ago. 9.0:1 comp. Right or wrong thing to do, unsure. It’s hardly turned it into a dog though. 🤷‍♂️.
Interesting topic and one that never comes to a black and white answer.
  • Like 1
Sounds logical
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
