The more I looked at my ac condenser the more I noticed how bad of shape is really was, so as much as it killed me to pay the asking price I bought a new one
and here it is fitted to the car and also I painted the fan and bought a brand new receiver dryer as well
  • Like 4
Looks purdy
You'll be glad you did replace it when it's all buttoned up
Whislt most wouldn't be able to notice a old busted arse condenser and dryer, you would have been jaded if you didn't change it when you had such easy access
  • Like 1
On 30/10/2021 at 10:55 AM, r32-25t said:
Thanks mate, every time I think “do I really want to?” I end up just saying if I don’t do it now I’ll never do it
Fk yeah, horny looking now.
  • Like 1
So far every time I haven't just bought the part while it was available I've regretted it. I swear everyone and their mother is hoarding parts like they plan on scalping them in a year or two.
You can thank the USA for f**king that up for everyone, before they were allowed to have them these cars and their parts were cheap and plentiful.
  • Like 1
  • 4 weeks later...
On 8/12/21 at 8:17 AM, iruvyouskyrine said:
Who did your elctroplating on the bolts and how much did it cost? Looks like it was worth it unless its stupid expensive
Elite plating in smithfield, was $150 for every nut, bolt and washer in the bay and on the engine, also did the bonnet prop and latch and a few brackets
What colour did you do the Bonnet stay?
not sure what to do with mine
I did it in the olive which is the original colour, if I could go back I would have just done the whole lot in gold
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
