Singapore Noodle Soup!  It is a bit of a dog of a job but so satisfying when it's done!  I'll be doing mine for the second time at some point which I'm not looking forward to.  It's amazing how much neater you can make it all look with some well routed wiring.
Enjoy! 😁
  • Like 1
There won’t be a single Nissan ecu sensor on the engine any more which basically made the original harness completely redundant, I was trying to pay someone to do this but everyone I spoke to had either stopped doing it or just came across as an arrogant prick
I'd stop doing it or be an arrogant prick if I had to do wiring all the time too! 🤣🤣
  • Haha 2
Been doing some part collecting
first we have the oil pump blank because of the external pump the engine will now have
new set of cam gears from prp, my old ones were fine but I like the locking system prp have come up with on their versions
new timing belt, tensioner, idler, washer and crank gear
brand new rear main seal housing just because
and all new seals from nitto (they came in the full gasket kit)
  • Like 4
Haven’t touched it again yet, will get try and get the body wiring back into shape and taped up soon then need the engine to be able do the rest
i know how you feel about all the car doing is collecting parts and dust
  • Like 1
  • 1 month later...
  • 3 weeks later...
Thanks, yes it does and I’m pretty sure it’s the first time I’ve seen it out of the box. I opened it a couple of times but I’m pretty sure I never took it out
  • Like 1
On 9/9/2022 at 7:00 PM, r32-25t said:
shit just got real
Haha, I was going to call you yesterday afternoon, I went past APM to see how they were travelling with my motor, they told me they just finished the billet one and mine was next. I though you’d be happy.
 My pistons have arrived.
  • Like 1
Your pistons arrived a lot faster then mine then, I would love to have seen them before they went in though, I put a camera down the spark plug hole and the crown is so big that they have an area to leave clearance for the spark plug electrode
Photo?
what compression ratio did you end up with?
photo of the head?
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
